I have no idea what my internal hard drive is because I'm using an old computer. Is there a piece of software that gives you the info on your hard drive? Stuff like 8MB buffer or 16MB buffer, and spin speed (7200).
Results 1 to 9 of 9
Thanks, I figured the old hard drive had a 8MB buffer and I was right. HDtune gives you the buffer, but it doesn't mention the spin speed.
Try Crystaldiskinfo or Crystaldiskmark. 8)
Check them here: http://crystalmark.info -
huh? Just go to the Bios and look at the model number or get the model number from the Device manager, then go online and look it up.
Another program is SIW. Gives you an incredible amount of info about a PC, including the drives. And there's a freeware version
: http://www.gtopala.com/
Does it give you the info for external drives? I tried HDtune on my external drive and got nothing.
SIW works on my external 500GB Fantom USB HDD. Gives a whole page of info. If you use the 'SIW Standalone (English-Only)' version , nothing is installed to your computer: http://www.gtopala.com/siw-download.html
DVD player to connect to a PC hard drive, or a networked hard drive?
By lifengwu in forum DVD & Blu-ray PlayersReplies: 0Last Post: 8th Oct 2010, 19:40 -
SATA, Hard Drive, Desktop only picking up part of the hard drive?
By Ghtpua in forum ComputerReplies: 9Last Post: 16th May 2010, 18:46 -
Sony Vaio with partitioned hard drive(Want full hard drive space on C)
By neworldman in forum ComputerReplies: 11Last Post: 17th Mar 2010, 13:42 -
Hard-Drive write caching,Is my hard drive faulty
By jezzer in forum ComputerReplies: 33Last Post: 27th Sep 2008, 11:06 -
question about where bad hard drive disk sector info is stored
By jimdagys in forum ComputerReplies: 1Last Post: 20th Apr 2008, 16:24
