I'm using virtualdub to merge videos but it says that the sampling rate is not the same but I have made both videos the same frame rate of 23.9700
Results 1 to 9 of 9
my first video has no audio but the 2nd video has audio. Do both video must have audio?
frame rate usually refers to video (e.g 23.976 fps), sampling rate usually refers to audio (e.g. 48000 Hz)Originally Posted by hech54
Blank audio and no audio are different things. Doing what baldrick suggested above will remove the audio; this won't work unless you remove the audio for the 2nd clip as well.
You need to add blank audio to the clip that has no audio, the same specs as the 2nd audio (channels, sampling rate etc...). You can do this with avisynth, then mux it with the 1st clip using avimuxgui. I think you can generate blank audio with audacity as well. Please post the the mediainfo on the 2 clips (view=>text)
Merge/add videos
By umurtaza in forum Newbie / General discussionsReplies: 0Last Post: 7th Nov 2011, 08:51 -
Need to batch-convert videos to MP4 using same bitrate as source videos
By BLboy in forum Video ConversionReplies: 7Last Post: 26th Jan 2011, 22:25 -
mkvmerge is not splitting videos to dvd5 size+ rotating videos+resizing
By rocketman122 in forum EditingReplies: 2Last Post: 24th Aug 2010, 09:12 -
How to make a compilation of 4:3 videos and 16:9 videos together on a dvd?
By pedrotc2002 in forum Newbie / General discussionsReplies: 13Last Post: 26th Feb 2010, 18:35 -
Conversion usiing VirtualDub - 720 X 560 videos into 640 X 360 videos
By candyman9999 in forum Video ConversionReplies: 1Last Post: 13th Jan 2009, 23:13
