Transferring VHS and Beta to DVD using my Sony DVD recorder. I've found the quality so far very good. I've just acquired a Sony Digital8 camcorder that allows analog-DV passthrough. If I use it in the middle, will that provide video quality benefits to me over just connecting my tape players to the DVD recorder directly using S-Video / RCA?
DV camcorders with pass-through may provide some timebase correction (horizontal line jitter reduction). Results vary so try it both ways and judge for yourself.Originally Posted by scotty123
Some DV camcorders also have the +7.5 IRE black level error (aka washout error*) with pass-through. Some DVD recorders have a record black level control to correct this.
* 7.5 IRE black gets mapped to digital level 32 instead of correct digital 16.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
If your dvd recorder can handle the analog video fine, I wouldn't put something in between it because that's just another encoding place that can lose a generation of quality. Best to have the shortest and most direct connection.
A DV camcorder would output digital DV over IEEE-1394 so there is one A/D and encode either way. It would be easy to compare the camcorder vs. the DVD player A/D using the same test source.Originally Posted by KnightmessengerRecommends: Kiva.org - Loans that change lives.
If you don't need to edit the video, just stick with direct tape-to-DVD recorder. It will save you time.
True. But my guess would be that the converter chip in the recorder would do better than the one in the camera. In fact a friend did that using his miniDV camera once from my Hi8 and the resulting video on the miniDV tape had a lot of broken pixels.Originally Posted by edDV
That would be unusual.Originally Posted by KnightmessengerRecommends: Kiva.org - Loans that change lives.
Analog to Digital Video Converter crapping out
By ScottL in forum Video Streaming DownloadingReplies: 7Last Post: 3rd Sep 2010, 14:01 -
Portable PAL analog (yes, analog!) television set
By stuey123usa in forum Capturing and VCRReplies: 0Last Post: 22nd Jun 2009, 19:23 -
Analog vs Digital TV
By J. Baker in forum Newbie / General discussionsReplies: 9Last Post: 10th Jan 2009, 03:21 -
Analog to DV Tape vs. Analog directly to computer
By jlorelle in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 16Last Post: 7th Sep 2008, 09:45 -
Which camera with analog to digital converter?
By kb1985 in forum Newbie / General discussionsReplies: 5Last Post: 22nd Jan 2008, 18:55
