i am using FAVC to convert my DV-AVI that i capture from my JVC camera to DVD
i found that there video is not smooth like the DV-AVI file
asking here and there and people said that i should encode using interlaced and BFF
i noticed that HCenc encode using ZIGZAG mode not interlaced and not BFF
how can i make FAVC encode using interlaced and BFF
thanks?
Results 1 to 11 of 11
i'll try that software,but i hope that the problem of the dvd is not smooth as DV-AVI is the interlaced option only..cause i am out of ideas
Yeah, but whether zigzag or alternate scanning were used has nothing to do with whether or not it was encoded as interlaced (although alternate scanning is prefered for interlaced encoding). I expect it was encoded as interlaced (as opposed to progressive). It is possible that it was encoded as TFF where it maybe should have been encoded as BFF. If the wrong field order was assumed, it would play real jerky. You can use ReStream (among other apps) to discover which field order was set in the encoder. In the 'Picture Encoding Extension' section either the 'Top Field First' box will be checked or it won't (meaning BFF). It'll also tell you if it was encoded as interlaced (the 'Frametype progressive' box will be unchecked).
I couldn't tell you, unless you want to upload a short 10 second sample of the DVD output from a section that shows movement. Use the [ and ] buttons of DGIndex to isolate a small piece and upload it to a 3rd party file hosting site, one like MediaFire.Originally Posted by obadvw
today i tried AVStoDVD and the result was Greatttttt
better quality and smooth motion
can you suggest me a good bitrate so i can put around 3 hours of video on single 4.7 DVD?
one more thing
when i tried to play it on my laptop it wasnt as smooth as on the pc
suggest me a good codec to put on my laptop
thanks;
how to override index signal function
By cmeffa in forum DVD & Blu-ray RecordersReplies: 2Last Post: 2nd Feb 2012, 02:19 -
Override component video resolution limit?
By BradSk88 in forum Newbie / General discussionsReplies: 2Last Post: 9th Sep 2011, 19:25 -
Multiavchd:override presets by using custom x264 cli
By lutinor in forum Newbie / General discussionsReplies: 0Last Post: 4th May 2011, 03:53 -
What standalone DVD players will allow me to override auto-repeat, etc?
By ambushed19 in forum DVD & Blu-ray PlayersReplies: 7Last Post: 3rd Aug 2009, 15:42 -
Can we override size that is used in AutoFit ?
By madusmacus in forum SVCD2DVD & VOB2MPGReplies: 6Last Post: 5th May 2008, 15:03
