Okay....so I went and used the "Pinoy2201's Divx Newbie Guide"
and everything worked out great for me. ...but
The dvd i'm ripping is a music video dvd..... What i'm doing is taking certain music videos and making them into their own divx files.
So far i've managed to get them all except one. The only reason is that my ifo file (that I got using DVD decrypter) doesn't have the rest of my dvd?? -(when using dvdx 1.7)---> well it gives me this error and then closes my ifo file (error: "MPEG2Dec: Error During seeking file").![]()
So, i'm assuming it has to do with this......(i may be doing something wrong and maybe i'm completely off...but its a theory)
... this specific dvd has alot of secrets and hidden features/options.
<EX: one feature is that when you play it on your computer the first time you won't be allowed to press forward/backward. then after the third time you will be or a certain part of the dvd won't be played until ... etc.>
I opened DvD decrypter again to take a look at the iso and vob files it had selected as "main files" I noticed there were more iso files and vobs and I even tried to see if the other iso files and vobs would work as main files...but nope.
so my question is:
When using DVD Decrypter what do I need to do to know which vob files are REALLY main files and which Iso files are REALLY corresponding with them? And if there's a way I can tell what do I need to do to get the other iso files to maybe <looking for the right word> sync? correspond? with that particular iso's vobs? Or am I just completely off all togethor??
Any tips or help would be greatly appreciated
Thanks ~nerm
Results 1 to 1 of 1
Backup main movie from DVD9 to DVD5 with main & chapter menu's.
By ChibiTomo in forum User guidesReplies: 18Last Post: 18th Jan 2010, 19:27 -
Question about possible virus that won't allow seeing hidden files
By jimdagys in forum ComputerReplies: 24Last Post: 1st Dec 2009, 07:09 -
Solved: How to change forced hidden attribute of folders/files
By jimdagys in forum ComputerReplies: 0Last Post: 1st Jul 2009, 00:07 -
ImgBurn hidden files and FixVTS issues
By PCat in forum Newbie / General discussionsReplies: 0Last Post: 8th Feb 2009, 17:06 -
Which files are the main movie
By RemainsHuman01 in forum Authoring (DVD)Replies: 1Last Post: 7th Aug 2008, 14:38
