I'm having trouble with this part.Enter the current volume label for drive d: (or whichever drive you chose)
Enter the volume name you noted down earlier and press ENTER.
Results 1 to 14 of 14
Okay... what exactly are you doing ?
& with what ?
Because if you are trying to convert an HDD on your PC there is an easy DOS command you can use to convert from FAT to NTFS without losing any information or files that may be on that drive. -
Converting and external drive from FAT32 to NTFS
open command prompt
type - convert x: /fs:ntfs
then it ask you for the current volume label
what do i put? -
If you use Convert.exe to convert a FAT32 partition to NTFS and the volume has a label, the following message is displayed:
Code:The type of the file system is FAT32. Enter current volume label for Drive X:
You can just hit enter or name the volume label/partition name whatever you like or use same volume label as the current one(see in windows explorer or type vol in cmd).
Use to DIR command to see what the current label is. For example,
C:\>dir c:
Volume in drive C has no label.
C:\>dir d:
Volume in drive D is Data
In this case drive C: has no label and drive D: has the label Data. If I recall correctly this is to help ensure you are converting the volume you think you are converting. If you use the command "convert c: /fs:ntfs" and reply that the current label is "Data" you should get a warning.
If your drive has no label, just hit enter.
-drjtechThey that give up essential liberty to obtain a little temporary safety deserve neither liberty or safety.
--Benjamin Franklin -
Yeah i don't even have my drives labeled... other then C: D: E: ect. ect.
After entering the label and pressing enter it gave me this.
This drive is dirty and cannot be converted. You will need to clear the dirty bit on this drive by running CHKDSK /F or alowing the AUTOCHK to run on it the next time you reboot.
The conversion failed.
X: was no converted to NTFS
What should I do now?
[CHKDSK] & [AUTOCHK] isn't working with my external drive. -
This is also how i have done it several times on various machines,
Q: Is it possible to convert a FAT32 Hard Drive to NTFS without losing all data on the
drive? I like to change from FAT32 to NTFS, my operating system is Windows XP PRO,
how can I do that? Without the lost of my programs?
A: Standard Windows utility that is called CONVERT serves this purpose
Just go to the Command Prompt and execute the command:
C:\> CONVERT C: /fs:ntfs
Where C: is a name of the drive you want to convert.
After machine re-boot conversion process will start and you'll
have your FAT32 converted to NTFS without of data loss. -
X:\CHKDSK /X The type of the file system is FAT32. Windows can set log file size on NTFS volumes only.
If a drive has no label, you can right click the drive and select properties which will show a box for label where a a label for the volume can be entered. My C drive is labeled DISK1_VOL1, but that can be changed or removed by leaving the box blank as you wish.
To run "chkdsk /f" on a drive you need to enter "chkdsk /f x:" where "x" is the letter of the drive you wish to check. This will give message that the drive cannot be locked and ask if you want to do it on the next restart. Answer "Y" for yes and restart.
Converting FAT memory stick to NTFS
By SE14man in forum Newbie / General discussionsReplies: 7Last Post: 15th Oct 2011, 00:47 -
FAT+ troubles with .mkv merged files
By fabpozzi in forum Media Center PC / MediaCentersReplies: 2Last Post: 19th Jan 2011, 10:29 -
Is it worth changing HDD over to FAT for playing on Sony Blu Ray player
By Dankriss in forum DVD & Blu-ray PlayersReplies: 11Last Post: 17th Jul 2010, 19:40 -
Subs fat and blurred on VOBs on my Hard disk, Not on DVD
By stumerr in forum Newbie / General discussionsReplies: 4Last Post: 19th Jun 2010, 23:17 -
Security bits in FAT & NTFS?
By G)-(OST in forum ComputerReplies: 9Last Post: 22nd Aug 2009, 14:16
