I decided to look for a new heatsink for my cpu since it started to get to 61c while encoding,after viewing heatsinks at newegg.ca i decided i might get this one.
http://www.newegg.ca/Product/Product.aspx?Item=N82E16835103046
Anyone with a similar setup find that its worth replacing,most reviewers at newegg are newbs and gamers,just need to know if it will keep the cpu cooler while encoding at full load.
Results 1 to 12 of 12
i'd go with something more like one of these.
http://www.newegg.com/Product/Product.aspx?Item=N82E16835103055
http://www.newegg.com/Product/Product.aspx?Item=N82E16835233012 -
Plus make sure you read up on how to apply your compound if the heat pipes ar actually part of the base (ie, there are little slot long gaps)
Thanks for the link minidv2dvd,thing is that heatsink it too big for my case on the first and the second doesnt have free shipping,i use artic silver 5 and i'll read up on the heatpipe method of applying the as5,ty for the tip stiltman
Found a better heatsink and going with this-
http://www.newegg.ca/Product/Product.aspx?Item=N82E16835233003I think,therefore i am a hamster. -
that one you list is the same as the second one i listed, but with a black fan instead of red. one of the ones you thought ws too big.Originally Posted by johns0
it stands up 159mm off the cpu. -
Its the same as the second but with free shipping(just realized its the same
) and even tho the first is the same height its much cheaper than the first one,i checked and it fits my case.
I have a Phenom II 940 w/ a CoolerMaster V8, I get 61c* during encoding w/ 1.5 cpuv on a 90F*+ day w/ added NBvOriginally Posted by johns0
What is your present hsf/cpuv/NBv/multiplier/bus clock?
ocgw
peacei7 2700K @ 4.4Ghz 16GB DDR3 1600 Samsung Pro 840 128GB Seagate 2TB HDD EVGA GTX 650
https://forum.videohelp.com/topic368691.html -
Its all stock settings,the mobo isnt very good at oc cause i bumped it to 3.4 gb(17x200) and it reset while doing an encode after a couple minutes,doesnt reset on stock settings,was a very hot day when it got to 61c tho.Cpuv is at 1.328.Originally Posted by ocgwI think,therefore i am a hamster.
LOL 90F*Originally Posted by jagabo
To johnsO: Yeah, sounds like you need a hsf bad, that Xigmatek will probably get you within a couple degrees of the best hsfs
ocgw
Just installed the HDT-S1283 and encoding on a hot day and its at 46C.
CPU Fan has failed please advise
By V Bot in forum ComputerReplies: 21Last Post: 23rd May 2010, 15:47 -
CPU Fan Died, Why No Warning?
By DarrellS in forum ComputerReplies: 14Last Post: 21st Feb 2010, 19:15 -
Any member using the Noctua NF-R8 80mm Fan on top of the CPU heatsink ?
By blinky88 in forum ComputerReplies: 3Last Post: 12th May 2009, 23:42 -
INTEL 478 socket - 775 socket heatsink/fan
By blinky88 in forum ComputerReplies: 7Last Post: 7th May 2009, 10:38 -
what heatsink/fan would fit?
By gooberguy in forum ComputerReplies: 5Last Post: 25th May 2008, 17:07
