so I was trying to convert a mkv file to avi ,
however when i got to the part taht i need to save the track i have a problem - after clicking the "save WAV" button
a window opened and i wrote as it said "name.mp3", clicked save and then i came across with this window[picture].
and i wonder what audio decompressor do i need more? i was working just as the manual told me.
thanks for all those who'll try to help
	You have 1 AC3, and 2 Flac streams.
 Check to see which stream you want (some might be different languages), you should be able to preview them in a media player (switch between them)
 You can "repackage" your mkv with mkvtoolnix (select the streams you want, deselect the streams you don't want) ; or did you want to keep all 3?
 Did you want an "AVI" that is compatible with a standalone player? If so, you might have to resize it as well as most support only standard def. "AVI" is just a container, so what is your reason for wanting it? ie. why not leave it as is? If you re-encode with a lossy codec, you will lose quality
 If the 1st audio track is the language you want to keep, it's just plain 6-ch ac3 , and compatible in AVI container. You would need AC3 ACM installed for vdub to "see" it
	the main reason was my COWON 02 PMP player, and i have tried to watch it via mkv but if i recall correctly there was no sound, or maybe also neither the video which means lack of support to the mkv files. therefore, i wish to have the video in AVI, the most simple and used format.
 thanks for the AC3 ACM decompressor, i have installed it and now there's new error :P
  MKV guide, Play MKV, MKV to AVI, MKV to DVD, MKV to MP4, MKV to Blu-rayBy Baldrick in forum Newbie / General discussionsReplies: 55Last Post: 29th Jun 2012, 12:19
  Error in Virtualdub while converting mkv to aviBy anchonio in forum Video ConversionReplies: 6Last Post: 1st Aug 2011, 03:36
  Convert AVI (miniDV) to MKV/MP4, large files only convert partiallyBy Video Eddie in forum Video ConversionReplies: 0Last Post: 3rd Jan 2011, 06:44
  Convert MP4 and MKV using AVISynth 2.5 and VirtualDubBy DruidCtba in forum Video ConversionReplies: 0Last Post: 7th Nov 2009, 08:51
  Convert MKV to AVI?? Is there an Easy Way like with VirtualDUBBy sandman423 in forum Video ConversionReplies: 4Last Post: 30th Jun 2007, 14:41
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
