Hello,
A few months ago I captured about 2 hours of footage directly from a DV camera, via Firewire, into Final Cut Pro. This generated a file about 8.5GB large in the capture scratch. Unfortunately, the file seems to be corrupt - it won't play in Final Cut, nor Quicktime, nor VLC, nor anything else I've tried. But the data is there - the file is 8.5GB, so there must be something there! I suspect that the capture didn't finalise properly, perhaps the computer crashed or something meaning that the file header wasn't written properly. Any ideas how I might go about recovering the video?
James
	the video you captured, was it on one tape or two? miniDV tapes are only one hour long. if you had captured 2 hours the file size would be around 26GB. something didn't work, and you should capture the tape(s) over again from scratch.
 [edit] welcome to the forum!
	It appears to be a possible codec issue. Quite possibly, you did not maintain the DV format, or else the file size for 2 hours would have been more than three times that size, as minidv2dvd explained. If not a codec issue, your file size might otherwise suggest the capture process froze up about a third of the way in. Were you monitoring your captures?
 Finalizing is done only for disc-based recordings, not tape-to-harddrive captures.
 Also, as minidv2dvd asked: how do you get 2 hours from minidv source to a single file? That would require a tape change, forcing separate captures that would create at least 2 files.
 There's something screwy going on here.
	Hello,
 The footage was not recorded on to miniDV tape then captured; it was captured directly in to Final Cut, i.e recorded directly to hard disk.
 I can't recapture from miniDV as it was never recorded on to miniDV in the first place.
 I've tried importing into VirtualDub - no joy.
 Any ideas how I could try to recover the corrupt file?
 James
	Theres another chance that while the file is not playable ... have you tried to export it in final cut pro?
	final cut would have recorded in dv raw in a mov container. if there is anything there it would show up if you import it into final cut. file size would indicate maybe 40 minutes of dv.
  Recovering and playing 3gp fileBy vain in forum Newbie / General discussionsReplies: 1Last Post: 14th Jun 2011, 03:29
  Recovering an MP4 FileBy RoblesGT in forum Newbie / General discussionsReplies: 0Last Post: 8th Aug 2010, 16:43
  corrupt video file preventing authoring?By feh in forum Authoring (DVD)Replies: 3Last Post: 15th Feb 2010, 14:41
  Recovering .mov file from SD cardBy Suprman37 in forum Newbie / General discussionsReplies: 2Last Post: 27th Oct 2009, 15:00
  Recovering Video FilesBy Cougar94 in forum Newbie / General discussionsReplies: 1Last Post: 18th Feb 2008, 14:50
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
 Quote Visit Homepage
				Visit Homepage
