I have a personal DVD that was copied from tape onto DVD using my Panasonic recorder. I would now like to edit it using windows movie maker or similar. But the DVD now has the file attatchments .bup and i cannot get it changed and have no idea of what to do next. Windows will not accept .bup
Help please.
Many thanks.
If you really want to use movie maker then try vob2mpg on the dvd and try import the mpg in wmm. You probably need a mpeg2 decoder installed, ffdshow might work fine.
Or else maybe try a dvd editor like mpeg video wizard, tmpgenc authoring works, videoredo and read https://forum.videohelp.com/topic257114.html -
what i really should have written, is that every time i use a DVD program (movie maker, cyberlink, HP) it tells me it is the codecs, and that it cannot read a .bup file
Where do i go from here? -
A bup file is a very small "BackUP" file, a copy of the IFO, which is a kind of index.Originally Posted by firjam
It isn't a video file at all.
Baldrick's post above.Originally Posted by firjam
Recommended Format? Digital8 video to PS3 or PC format?
By fuzzysword in forum Video ConversionReplies: 5Last Post: 26th Apr 2010, 08:19 -
Realplayer files to another file format or dvd format
By vieya in forum Video ConversionReplies: 8Last Post: 25th Dec 2009, 13:12 -
Converting from Flash .flv format to iPod Compatible .mp4 format in ffmpegX
By bananasontoast in forum ffmpegX general discussionReplies: 1Last Post: 3rd Jan 2009, 10:15 -
Converting from DVD format to playable on MAC format...
By livvyramone in forum MacReplies: 2Last Post: 23rd Jul 2008, 09:21 -
Convert Coreldraw file format(cpt) to some other format like tiff
By mysts in forum Off topicReplies: 0Last Post: 31st May 2007, 11:38
