How can i view my PC on my TV?
So today i got a VGA to RCA cable to get my audio and video on my TV. So i plugged it in my computer and in my TV and went to the right TV mode where the cables were connected.
Here is how my cable looks like:
TV screen is blank. I spend hours on the settings of DISPLAY SETTINGS and NVIDIA settings and i have had no luck to get my desktop on my TV.
I have this NVIDIA Card: Nvidia GeForce4 440
In the display settings theres 2 screens, i click on the second but nothing happened. I tried everything, every setting there is, but still no luck.
Can someone tell me how this works?
				Results 1 to 9 of 9
	It doesn't.
 VGA is RGB with HV sync, not analog component.
 Does your TV have a VGA port?
 If not, you can buy display card with an analog component output.Recommends: Kiva.org - Loans that change lives.
 http://www.kiva.org/about
	Here you go:
 http://www.1topstore.com/product_info.php?products_id=1652
 It even says:
 Note:
 3RCA connectors: red, green, blue.
 If your jacks are red, white, yellow.
 please plug them as follows: red to red, green to white, blue to yello
 So i guess its right.
	I have put that VGA port into LAPTOP and the RCA ports into my TV and it doesnt work.
	It's a scam return it. North American TV sets use YPbPr not RGB.
 http://en.wikipedia.org/wiki/VGA
 http://en.wikipedia.org/wiki/Component_videoRecommends: Kiva.org - Loans that change lives.
	OK i am returning this tomorrow.
 Can someone tell me what wire to get to get AUDIO and VIDEO on my TV?
 Thanks.
	Tell us the model of your laptop and TV.
 Does the laptop have s-video or composite out?
 Does the TV have VGA, DVI-D or HDMI in?Recommends: Kiva.org - Loans that change lives.
	From your link, http://www.1topstore.com/product_info.php?products_id=1652 :Originally Posted by awaisuk
 That cable is for specific graphics cards which output component video (or composite plus audio) on otherwise unused pins on the VGA connector. Very few cards ever did this. Your laptop does not do this.Work with laptops and desktops with VGA cards that has TV-Out function capability through the VGA connector
 To give you advice on what to use we need to know what outputs are available on your laptop and what inputs are available on your TV. If there are no corresponding outputs/inputs you will need a scan converter which can get very expensive (hundreds of dollars).
  how to view old 3/4" videoBy newsshari in forum Newbie / General discussionsReplies: 2Last Post: 9th Nov 2011, 14:47
  Saving viewBy jyeh74 in forum Newbie / General discussionsReplies: 1Last Post: 14th May 2011, 15:18
  Video MetaData - How do i view this?By jmadden93 in forum Video ConversionReplies: 1Last Post: 12th Jun 2010, 14:49
  View folder changesBy jyeh74 in forum ComputerReplies: 5Last Post: 20th Oct 2008, 02:18
  Sansa View 8 GB Model how do I convert video for use with the sansa view?By goheadtry in forum Video ConversionReplies: 1Last Post: 2nd Jun 2008, 01:01
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
