Hi,
I have this music DVD and I want to do the following:
enlarge picture so picture fill the screen with no black margins ( I know how to do this)
but how to keep original DTS 5.1 sound?
I am using TMPGEnc 4.0Xpress as my program (4.6 version). I have decrypted dvd using dvd decryp and it has all 3 sounds. but when I load the dvd into TMPGENC it gives me 3 sound options (mpeg I audio layer II, Linear PCM and doly digital)
is linear PCM DTS 5.1?
thanx
				Results 1 to 9 of 9
	No, linear PCM is not DTS.
 DTS support in authoring tools is limited to higher end tools for the most part. DVD Lab Pro handles it, amongst others. Consumer tools tend not to because of licensing costs, and because DTS is not a common format for consumer cameras etc. AC3 is more than enough for the masses.
 What you will have to do is demux the DTS audio out of the DVD and re-author to put it back in using a tool capable of authoring with DTS. GUIForDVDAuthor supports DTS, however I cannot tell if DVDAuthorGUI or DVD Styler will.Read my blog here.
	i did everything u said added all 3 audios to my video using dvd lab pro played on ps3 nothing only got 5.1 dolby not 5.1 dts. but when i put the dvd in ps3 it does play it.....
	Well your whole project, from start to finish, could be quickly done with ConvertXtoDVD 3. The video resizing options (crop/pad) work well. It will also pass through DTS or allow you add a DTS audio stream to a project.
	ok i will do that guns1inger however does it matter if i rename the final vob into mpeg they are exactly the same right? maybe thats what causing the issue, or ps3 itself because it seems to me that the computer does recognise 2 audio on the file.
	A VOB is not an MPEG file, so you may not get what you want. I need to see the media info output to see if you actually do have two audio tracks. I am not yet convinced that you have authored it correctly. Read my blog here.
	Hi. I have a similar problem. I have an anime with DTS audio on an MKV file. I extracted the DTS audio and inserted it as the main audio on DVDLab Pro. It appears to encode it properly, but, when I play it, there is no audio. Actually, my player detects there is a DTS audio channel there, but there is no sound.
 Ps.: I don't understand the info on the log, as I'm not a programmer or developer, I just know how to create DVDs in a very amateurish way. So bear with me but am I missing some DTS encoding plug-in or something? Because I have inserted DTS files on DVDLab Pro compilations before, and they worked fine.
 Here is the project compiling log:
 4 - 11 - 2012 -- 15:50:3
 * VMG Verification *
 Number of VTS - 1
 Number of Menus: 2
 Menu 01 - Type - Dummy
 Menu 02 - Type - Motion
 Menu Video File C:\Users\ALEXANDRE\Documents\ANIME COPIED MOVIES\Howl's Moving Castle\Menus\main-0.m2v
 Frame size: 720 X 480
 Frame rate 4 [1--23.976, 2--24, 4--29.97, 3--25, 5--30]
 Aspect Ratio: 169 [43--4:3, 169--16:9]
 MPEG Video Type: 2 [1--MPEG 1, 2--MPEG 2]
 Chroma: 1 [1--4:2:0, 2--4:2:2, 3--4:4:4]
 GOP 1, size - 538246
 GOP 2, size - 165066
 GOP 3, size - 474313
 Menu Audio File C:\Users\ALEXANDRE\Documents\ANIME COPIED MOVIES\Howl's Moving Castle\Menus\main.ac3
 Audio type: AC3_Mot, Channel: 6, Sampling: 48000, Bitrate: 448000
 Menu Sub-Picture File C:\Temp\92010632_tmpsub1.bmp
 Picture size - 720 x 480
 nMenu cell count - 1
 Number of imported VTS: 0
 * VTS Verification *
 <<< VTS Number 1 >>>
 Number of Titles: 2
 Title 01 - Type - ES or PES
 Segment 1, Video File C:\Users\ALEXANDRE\Documents\ANIME COPIED MOVIES\Howl's Moving Castle\Files\Project_1\Howl's.Moving.Castle.2004.x 264.DTS.3AUDIO-WAF.m2v
 Frame Size: 720 X 480
 Frame Rate 4 [1--23.976, 2--24, 4--29.97, 3--25, 5--30]
 GOP 1, size - 16834
 GOP 2, size - 16779
 GOP 3, size - 267690
 Segment 1, Audio File : None
 Segment 1, Subtitle File C:\Users\ALEXANDRE\Documents\ANIME COPIED MOVIES\Howl's Moving Castle\Files\1.sp1
 Title 02 - Type - ES or PES
 Segment 1, Video File C:\Users\ALEXANDRE\Documents\ANIME COPIED MOVIES\Howl's Moving Castle\Menus\m0-m1.m2v
 GOP 1, size - 270925
 GOP 2, size - 312399
 Segment 1, Subtitle File : None
 Number of Menus: 11
 Menu 02 - Type - Still
 Menu Image File C:\Temp\92026336_tmp1.bmp
 Menu Sub-Picture File C:\Temp\92026336_tmpsub1.bmp
 Menu 03 - Type - Still
 Menu Image File C:\Temp\92659544_tmp1.bmp
 Menu Sub-Picture File C:\Temp\92659544_tmpsub1.bmp
 Menu 04 - Type - Still
 Menu Image File C:\Temp\112771736_tmp1.bmp
 Menu Sub-Picture File C:\Temp\112771736_tmpsub1.bmp
 Menu 05 - Type - Still
 Menu Image File C:\Temp\114489536_tmp1.bmp
 Menu Audio File C:\Users\ALEXANDRE\Documents\ANIME COPIED MOVIES\Howl's Moving Castle\Menus\setup.ac3
 Menu Sub-Picture File C:\Temp\114489536_tmpsub1.bmp
 Menu 06 - Type - Still
 Menu Image File C:\Temp\371319128_tmp1.bmp
 Menu Sub-Picture File C:\Temp\371319128_tmpsub1.bmp
 Menu 07 - Type - Motion
 Menu Video File C:\Users\ALEXANDRE\Documents\ANIME COPIED MOVIES\Howl's Moving Castle\Menus\ep1.m2v
 GOP 1, size - 228039
 GOP 2, size - 237705
 GOP 3, size - 265852
 Menu Audio File C:\Users\ALEXANDRE\Documents\ANIME COPIED MOVIES\Howl's Moving Castle\Menus\episodes.ac3
 Menu Sub-Picture File C:\Temp\297184920_tmpsub1.bmp
 Menu 08 - Type - Motion
 Menu Video File C:\Users\ALEXANDRE\Documents\ANIME COPIED MOVIES\Howl's Moving Castle\Menus\ep2.m2v
 GOP 1, size - 203935
 GOP 2, size - 188712
 GOP 3, size - 190499
 Menu Sub-Picture File C:\Temp\297190432_tmpsub1.bmp
 Menu 09 - Type - Motion
 Menu Video File C:\Users\ALEXANDRE\Documents\ANIME COPIED MOVIES\Howl's Moving Castle\Menus\transition-a.m2v
 GOP 1, size - 505635
 GOP 2, size - 246817
 GOP 3, size - 3157
 Menu Audio File C:\Users\ALEXANDRE\Documents\ANIME COPIED MOVIES\Howl's Moving Castle\Menus\transiton-a.ac3
 Audio type: AC3_Mot, Channel: 2, Sampling: 48000, Bitrate: 256000
 Menu Sub-Picture File C:\Temp\414968696_tmpsub1.bmp
 Menu 10 - Type - Motion
 Menu Video File C:\Users\ALEXANDRE\Documents\ANIME COPIED MOVIES\Howl's Moving Castle\Menus\1-subs.m2v
 GOP 1, size - 271113
 GOP 2, size - 316737
 GOP 3, size - 96574
 Menu Audio File - None
 Menu Sub-Picture File C:\Temp\259469416_tmpsub1.bmp
 Menu 11 - Type - Motion
 Menu Video File C:\Users\ALEXANDRE\Documents\ANIME COPIED MOVIES\Howl's Moving Castle\Menus\1-chap.m2v
 GOP 1, size - 271175
 GOP 2, size - 317181
 GOP 3, size - 96371
 Menu Sub-Picture File C:\Temp\414512392_tmpsub1.bmp
 * Status Messages *
 Start building Video Title Set ( VTS ) ... - 2001
 Title - 1
 Start building VOB streams - 2210
 Muxing elementary streams is in process ... - 2220
 [INFO] - No audio stream is provided - 3019
 Muxing is in process ... - 2300
 Creating PGC for the title is in process ... - 2500
 Title - 2
 [INFO] - No subtitle stream is provided - 3739
 Verifying Closed Caption file is in process ... - 3750
 Creating dummy menu is in process ... - 2790
 Creating still menu is in process ... - 2700
 Start encoding bitmap ... - 2750
 Reading bitmap is in process ... - 2740
 Initializing audio packets ... - 3005
 Initializing AC3 (MOT) audio packet ... - 3030
 Audio stream is provided - 3017
 Encoding bitmap and building VOBU is in process ... - 2450
 Audio packetizing ends - 3025
 Creating motion menu is in process ... - 2600
 Building VTS IFO stream is in process ... - 2800
 Start building Video Manager (VMG) ... - 2005
 Building VMG IFO stream is in process ... - 2850
 *** Post Verification ***
 No error was found in the post verification process
 Authoring is successfully completed - 3900
  3d video with dts sound how to convert to ac3 soundBy fredddiemercury in forum Video ConversionReplies: 4Last Post: 2nd Nov 2011, 15:54
  Please Help? How to restore DTS sound on DVDBy amir3852 in forum Authoring (DVD)Replies: 3Last Post: 3rd Jan 2011, 17:31
  MKV2VOB problem with DTS sound...By theria05 in forum Video ConversionReplies: 1Last Post: 30th Jan 2010, 05:17
  authoring program with dts soundBy tommcd64 in forum Authoring (DVD)Replies: 3Last Post: 25th Feb 2008, 13:59
  Does removing DTS sound in movies help Dolby?By JohnnyBob in forum AudioReplies: 22Last Post: 11th Sep 2007, 16:53
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
