    Jun 2009
    I’m using ffmpeg to split .flv files without re-encoding but I’m having limited success. For example, in this case:
    ffmpeg -i michelle.flv -ss 00:00:00 -t 00:00:02 -vcodec copy -acodec copy michelle2.txt
    the file is one minute and 6 seconds long, instead of 2 seconds long.
    In this case:
    ffmpeg -i michelle.flv -ss 00:00:02 -t 00:00:02 -vcodec copy -acodec copy michelle3.txt
    the file is one minute and 8 seconds long, starting at 00:00:02 of the original but with no video from 00:00:00-00:00:02.
    Any suggestions?
    For reference, I posted the .flv files (input and output) here:
    http://drop.io/l92vi42
    The ffmpeg command output is here:
    $ ffmpeg -i michelle.flv -ss 00:00:00 -t 00:00:02 -vcodec copy -acodec copy michelle2.flv
    FFmpeg version SVN-r19159-Sherpya, Copyright (c) 2000-2009 Fabrice Bellard, et al.
    libavutil 50. 3. 0 / 50. 3. 0
    libavcodec 52.30. 2 / 52.30. 2
    libavformat 52.34. 0 / 52.34. 0
    libavdevice 52. 2. 0 / 52. 2. 0
    libavfilter 0. 5. 0 / 0. 5. 0
    libswscale 0. 7. 1 / 0. 7. 1
    libpostproc 51. 2. 0 / 51. 2. 0
    built on Jun 12 2009 04:25:02, gcc: 4.5.0 20090517 (experimental)
    [flv @ 0x2331650]skipping flv packet: type 18, size 294, flags 0
    Seems stream 0 codec frame rate differs from container frame rate: 59.99 (14997/250) -> 29.97 (30000/1001)
    Input #0, flv, from 'michelle.flv':
    Duration: 00:02:55.28, start: 0.000000, bitrate: N/A
    Stream #0.0: Video: h264, yuv420p, 854x480 [PAR 1:1 DAR 427:240], 29.97 tbr, 1k tbn, 59.99 tbc
    Stream #0.1: Audio: aac, 44100 Hz, stereo, s16
    Output #0, flv, to 'michelle2.flv':
    Stream #0.0: Video: libx264, yuv420p, 854x480 [PAR 1:1 DAR 427:240], q=2-31, 1k tbn, 1k tbc
    Stream #0.1: Audio: 0x000a, 44100 Hz, stereo, s16
    Stream mapping:
    Stream #0.0 -> #0.0
    Stream #0.1 -> #0.1
    Press [q] to stop encoding
    frame= 2000 fps= 0 q=-1.0 Lsize= 4616kB time=66.65 bitrate= 567.4kbits/s
    video:3749kB audio:780kB global headers:0kB muxing overhead 1.923058%
    $ ffmpeg -i michelle.flv -ss 00:00:02 -t 00:00:02 -vcodec copy -acodec copy michelle3.flv
    [flv @ 0x2e11650]skipping flv packet: type 18, size 294, flags 0
    Output #0, flv, to 'michelle3.flv':
    Stream mapping:
    Stream #0.0 -> #0.0
    Stream #0.1 -> #0.1
    frame= 2000 fps= 0 q=-1.0 Lsize= 4791kB time=68.58 bitrate= 572.3kbits/s
    video:3900kB audio:802kB global headers:0kB muxing overhead 1.881003%
    Sep 2007
    Europe
    It's a bug in the FFmpeg version you use (tried it and got 1m 6sec).
    Try the latest build from here; http://ffmpeg.arrozcru.org/autobuilds/
    With that one I get 2s 33ms.
    Jun 2009
    That worked great Chris! Thanks so much!
