I am trying to get text to scroll up like credits but not sure where it is. Also can i import a text file into this to save typing it all out again. Thanks a lot.
Might be the same or close enough for you to figure out
http://answers.yahoo.com/question/index?qid=20071005125216AAPv6al
In Ulead VideoStudio 11:
1. Click on the 'Title' tab.
2. Go to the place in the video where you want the credits to appear.
3. Double-click the preview screen. A text box should appear on the preview screen.
4. Type in the credits/text you want. For credits, I would suggest leaving many lines of empty space between each separate credit.
5. Click on the 'Animation' tab for titles.
6. Check off 'Apply animation'
7. Where it says 'Type:' choose 'Fly' from the dropdown menu.
8. Go to 'customize animation attributes,' which is the button next to the dropdown menu that looks like 2 T's.
9. Make sure where it says 'start unit' and 'end unit' that you have 'text.' And where it says 'pause,' make sure it says 'no pause' in the dropdown menu. Also make sure the enter and exit direction arrows are both in the up direction.
Ulead Video Studio 9 - colorspace
By Froddy1 in forum EditingReplies: 0Last Post: 2nd Feb 2009, 10:49 -
Ulead Video Studio 11 (to dvd)
By Firesign in forum Newbie / General discussionsReplies: 1Last Post: 20th Dec 2007, 12:23 -
Ulead Video Studio 10 avi help
By theguy1991 in forum Newbie / General discussionsReplies: 15Last Post: 25th Oct 2007, 15:57 -
Does anyone use ULEAD Video Studio 10?? or any suggestions?
By cmlmich in forum Newbie / General discussionsReplies: 1Last Post: 2nd Jun 2007, 22:12 -
Ulead Video Studio 7 SE
By uricktam in forum Newbie / General discussionsReplies: 1Last Post: 10th May 2007, 11:14
