Hi,
Can somebody tell me some command line tools and their donwload location, which can be used for dvd authoring.
My requirements are
1. It should take avi files as input and create a VOB structure.
2. It should allow me to create various chapters and menu to navigate easily.
P.S. -- I tried using DVDAuthor but the problem is that it is not taking avi files as input, It requires .mpg files. So i have to convert them using ffmpeg which is an overhead.
So I m looking for something which can avoid these conversion.
Cheers,
Sumit
Closed Thread
Well you must convert the avi to dvd mpeg2 format to be able to make a DVD-Video. So you must use a converter like ffmpeg.
The problem with ffmpeg is that it is too slow.
Can i make the conversion fast?
Currently for a 30 min / 220mb avi video, its taking 20 mins to convert it into .mpg format which is quite long.
Can i reduce this time somehow?
Faster cpu.
ANd PLEASE STOP MAKE NEW SIMILAR TOPICS. Use your other topics, just reply to add new information. Like https://forum.videohelp.com/topic369529.html .
Linux command line tools for Converting AVI to H264/AAC mkv
By Psykro in forum LinuxReplies: 9Last Post: 6th Oct 2011, 22:21 -
Need Command Line video joiner (preferably free tools)
By Nintynuts in forum Newbie / General discussionsReplies: 5Last Post: 25th Mar 2010, 18:36 -
any (free) command line tools for converting swf to other formats?
By kkol123 in forum Video ConversionReplies: 1Last Post: 7th Dec 2008, 23:42 -
Any command line tools for splitting (and/or joining) video files?
By kkol123 in forum EditingReplies: 8Last Post: 4th Dec 2008, 19:35 -
H264: Are there other h264 (AVCHD/VC-1) encoding command-line/CLI tools ??
By vhelp in forum Newbie / General discussionsReplies: 12Last Post: 16th Feb 2008, 02:20
