OK I am trying to capture some HD video off my new Sony HDV Z5E camera... I have a trial version of Vegas Pro 9... I plugged it all in and started to capture... But when the files ended up on my computer they are .m2t files ??? I was expecting MPEG2 files![]()
Am I doing something wrong ? Help please...![]()
Results 1 to 11 of 11
Hey Minidv2dvd... thanks for the input... I guess I need to know what settings to set
I couldnt see the non square pixels bit... however I see a option that is called "Pixel Format" the options in there are 8-bit 32-bit floating point (video levels) and 32-bit floating levels (full range) any suggestions which I should use ?
Also it has motion blue set to "Gaussian" is that right ? Other options are Pyramid, Box, Pyramid (asymmetric), Box (asymmetric) ??? I am such a newbie lol -
before you import your files, go to file properties, click the drop down arrow next to template. select the HDV template that matches your source files. most likely "HDV 1080-50i (1440x1080, 25.000 fps)" you can leave the rest of the settings alone. put a check mark in start all new projects with these settings if you want to. click apply, then ok.
Moving you to our camcorder section. This is not analog capturing.
Thanks Admin for putting us in the right place
And thanks Mini I dont that
So I dont need to mess around with anything else phew
Alas no more comments since being moved lol...
Another quickie... as well as getting the m2t file... it also has a .sfk file, anyone tell me what this is as well ? If I am going to copy all of the content onto a hard drive for a client what do I need to include... can I put just the mpg, or should i include the m2t and sfk files as well ?
And just to clarify once I captured the video as m2t files, if I change the .m2t to mpg the video will work right ? So I dont need to render or publish or anything techie, I can simply change the extension... -
Soundeffects???Originally Posted by pixelbucks
Really I don't have a clue on that one since I dont' own a high def camera.
HOWEVER:
I would not do this. Especially if its not for your own project. Leave the original files intact. Include everything that was recorded on the camera.Originally Posted by pixelbucks
Most prosumer editing suites that work with highdef video should be handle them as is without any coaxing.Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
ROTFLMAO
As you can see, most here don't even own cameras. However, it sure doesn't stop them from posting a guess. It may actually encourage them... -
ahhhhhhhhhhh............. pixelbucks what is the destination format? dvd? blu-ray?
no don't change the extension. it's mts for a reason. it's a type of high def mpeg transport stream. not a plain ordinary mpeg.
skf is a file added by sony vegas to store info of the file.
why are you sending out the files? we can't know what needs to go if we don't have any info on what's going on.
Bizzare problem capturing - NEWBIE
By Aarell in forum Newbie / General discussionsReplies: 2Last Post: 17th Jan 2012, 11:38 -
Newbie question - capturing and converting from DV
By zaspa in forum Newbie / General discussionsReplies: 8Last Post: 31st Aug 2011, 16:56 -
Newbie help with capturing !!
By hightimes420 in forum Newbie / General discussionsReplies: 3Last Post: 27th Oct 2008, 16:48 -
newbie capturing, show me the way: 8mm/VHS > DV
By nutshellml in forum Newbie / General discussionsReplies: 1Last Post: 21st Mar 2008, 07:37 -
Newbie question on Capturing to Encoding
By Lucky19th in forum Newbie / General discussionsReplies: 10Last Post: 16th Jul 2007, 14:09
