Hi All,
I'm authoring a project to DVD and like everyone else wants to use all available space as wisely as possible.
I've looked at the bitrate calculators in the tools section, but they don't cater for the situation I'm in. Part of the "assets/extras" that I have is an already encoded slideshow over which I have little control, and which is also multiplexed into the DVD structure as an additional titleset.
So in order to know how much space the extras - including the slideshow - will require, I need to know what the multiplexed size of the slideshow will be. (And from there it's but one extra step to put together my own DVD bitrate calculator).
At https://forum.videohelp.com/topic278684.html borax gave some information on DVD multiplexing overhead. Is that still the extent of our knowledge on this topic, or is there more information available?
Now, to complicate things further, both the slideshow and my movie have multiple SST subtitle streams. Does anybody have some guidance on calculating average subtitle bitrate + multiplexing overhead, and/or eventual size? I know these vary according to content and project, but perhaps one can make some fairly accurate extrapolations from the 4-colour compressed BMPs' total size, or maybe from the original SSA text even?
Many thanks in advance,
Francois
...fairly accurate extrapolations from the 4-colour compressed BMPs' total size, or maybe from the original SSA text even...
No. But if you convert the subtitle into sup (which is already the same format as on the final DVD), you can add the size of the sup files (maybe with an additional 10% for padding) to my 'usual' formula.GUI for dvdauthor:
https://www.videohelp.com/~gfd/ -
Thanks!
Originally Posted by borax
[edit]
Another question, in the GfD (with MuxMan) process, are the SUP files directly generated into the DVD VOBs, or are they first created as temporary files somewhere (in which case I can maybe insert a pause command in the batch files before the DVD creation process to have a look at the SUP file sizes)?
[/edit]
Cheers,
Francois -
...are the SUP files directly generated into the DVD VOBs
Yes. And there should be no additional overhead (or only minimal due to the 2k packeting of VOB units). So you can add the size of the sup files to the 'Total size' (using the above mentioned formula).GUI for dvdauthor:
Low overhead streaming server software
By Sierraguy in forum Video Streaming DownloadingReplies: 0Last Post: 7th Jul 2010, 23:55 -
xvid - how to calculate avi-overhead?
By Information in forum Video ConversionReplies: 4Last Post: 9th Nov 2009, 07:35 -
2875 X 768 px with 3000kbps overhead, wich settings?
By pisosse in forum ffmpegX general discussionReplies: 3Last Post: 8th Jul 2009, 13:57 -
Need to video from OVERHEAD...i.e. a Piano.
By Gromit137 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 5Last Post: 17th Oct 2007, 10:45 -
Taking Video from Overhead..i.e. Piano.
By Gromit137 in forum Newbie / General discussionsReplies: 1Last Post: 15th Oct 2007, 13:48
