I am trying to find a way to capture the videos from WWEclassics.com. All files have DRM and only seem to play in WMP. When I try and screen cap it slows the video down and choppy video happens.
Laptop output to a DVD recorder.
What software are you using to capture? What codec to capture?
You are probably dropping frames and whatever software you are using is probably too CPU intensive (especially if you are using some compression).
You should be able to get around this by using a faster PC setup , or less CPU intensive codec. If you use something like camtasia or camstudio + uncompressed or huffyuv (lossless compression) you should be ok even with older pc's.
Another method is to capture is use a dedicated WMV capture software like WMRecorder , then convert that wmv at a leisurely pace offline (The DRM usually doesn't expire for a week) , this way it's even less intensive, and you rule out bandwith being the culprit for frame drops.
Download or save Lovefilm videos?
By jakobmeh in forum Video Streaming DownloadingReplies: 1Last Post: 3rd Oct 2011, 11:03 -
How do you Record/save streaming videos
By jace89 in forum Video Streaming DownloadingReplies: 13Last Post: 22nd Sep 2008, 15:17 -
laptop output, to save online videos
By snafubaby in forum Newbie / General discussionsReplies: 1Last Post: 27th Apr 2008, 02:48 -
how to save these streaming videos
By 3lo in forum Video Streaming DownloadingReplies: 3Last Post: 17th Mar 2008, 01:01 -
I want to know how to save videos from veoh to my computer?
By chriskimber in forum Newbie / General discussionsReplies: 1Last Post: 13th Aug 2007, 18:36
