I know this is a stupid question, but I have an update to my car deck, that says it has to be burned in the DAO mode. I usually use Imgburn, yet I have not had to burn just files with it, I have just been using XP or Vista to make data disks in the past, but I do not know if they burn in that mode. It does not appear Imgburn will burn just a file??? I did have recordnow max awhile back, but dont have it anymore either. Any suggestions?
DAO (disc at once) or SAO (session at once) will work just fine. Most burning applications use these modes - many even confuse the two
Just don't burn TAO (track at once) for your data discs.
burnatonce
BurnAware Free
CDBurnerXP
Deep Burner
InfraRecorder
A short list of free burning applications.Linux _is_ user-friendly. It is not ignorant-friendly and idiot-friendly. -
IMGBurn can be set to DAO/SAO in the options.
I checked the write tab under settings in imgburn and it was already set to DAO/SAO. I just wanted to make sure before I call tech support and tell them their firmware update did not work for my deck. Instructions specifically said to burn as DAO or it would not work. Thanks.
Bluray player calling blueray disk "data disk" and saying no video files
By jbitakis in forum Authoring (Blu-ray)Replies: 10Last Post: 27th Nov 2011, 21:06 -
Pulling data from disk (DVD+R)
By Antares in forum DVD RippingReplies: 7Last Post: 10th Apr 2011, 08:28 -
WIERD DVD data disk problem
By bruinflight in forum Newbie / General discussionsReplies: 24Last Post: 24th Sep 2009, 23:53 -
Combining data files with a DVD movie on the same disk
By j_p in forum Authoring (DVD)Replies: 6Last Post: 26th Jun 2008, 01:52
