In my devices folder I see listed;
IEEE 1394 Bus Host Controllers
OHCI compliant IEEE 1394 Host Controller
If I do have firewire, what is so great about it compared to USB 2?
Thanks for any help!
You should be able to tell by your computer. Do you know what a firewire insert looks like?
Firewire port is different than a USB port. You should be able to tell the difference.
http://en.wikipedia.org/wiki/FireWire
Scroll down, they have pictures on the right. -
You can use the port for camcorders, pro equipment, some hard drives, networking, cable box MPeg-TS capture and the list goes on.
http://www.kiva.org/about
How can I tell if my VGA card has TV-Out function capability
By lily083 in forum Newbie / General discussionsReplies: 3Last Post: 20th Jul 2010, 16:26 -
WD TV capability
By jayantadak in forum Media Center PC / MediaCentersReplies: 2Last Post: 26th Apr 2010, 22:00 -
Motherboard and RAM Capability
By HotDamn! in forum ComputerReplies: 2Last Post: 8th Jan 2010, 22:32 -
Do you have video recording capability on your cellphone?
By yoda313 in forum PollsReplies: 32Last Post: 3rd Nov 2008, 05:37 -
Need a CC with PAL60 capability for the UK
By usernameinvalid in forum Capturing and VCRReplies: 21Last Post: 10th Oct 2008, 18:15
