Hi all, I really hope you can help me promptly as I am in quite urgent need with a tight deadline! Here's the deal.
I'm running the NewTek VT5 on a pc, capturing a live show. I'm currently in a rehearsal. All sources plugged into the VT5 are sending a 16:9 signal through S-video. The VT5 is outputting (at the moment) through an S-Video cable (but will be using component for the actual show recording) and we are capturing on a digital video recorder (datavideo DN-300). The problem is that the device isn't recognizing the 16:9 signal. It only seems to record in 4:3. Now I know that the system is capable of recording a 16:9 signal because I have captured directly from a camera through firewire and this worked fine.
So the question really is, is an S-video cable capable of sending a 16:9 picture that will be recognized as 16:9 by a digital recorder or can this only be done digitally through the firewire?
Hope this makes sense, found it difficult to make it clear what I wanted...
Changing pixel aspect ratio of video clip?
By Real Ramona in forum Newbie / General discussionsReplies: 7Last Post: 23rd Jan 2012, 11:20 -
Pixel Aspect Ratio in virtualdub
By wabsnazm in forum Newbie / General discussionsReplies: 6Last Post: 10th May 2011, 16:57 -
pixel aspect ratio?
By shun in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 5Last Post: 5th Aug 2009, 14:53 -
Which encoder keeps Pixel Aspect Ratio intact?
By hadiceberg in forum DVD RippingReplies: 11Last Post: 8th Jun 2009, 08:09 -
Aspect Ratio: Pixel AR and Display AR
By cheerful in forum Newbie / General discussionsReplies: 1Last Post: 15th Sep 2007, 18:42
