Hi,
This is the first time I am trying to make a DVD from my .AVI file. It is a video we took at home...
I am using laptop with DVD-RW drive and ConvertXtoDVD V3 - and trying to play on Panasonic DMR ES46V. I used a Dynex DVD-R disk to burn the video. I burned the DVD using default settings (or so I thought).
The problem is - when I try to play the newly created DVD on my Panasonic player (hooked to TV) - it says'
"Your selection exceeds the rating you have set. Change the rating to allow playback."
The DVD player is set to play all rating DVD (highest setting is 8). It plays commercial DVDs with no problem.
I do not see a setting in ConvertXtoDVD to set the DVD rating - can this be done? Is it my problem or might it be something else?
When I try to play the newly burned DVD on my laptop (which created it) - it seems to hang in space. The HP player screen came up but didn't play the DVD.
Am I missing something obvious here? any suggestions would be much appreciated.
Thank you,
Misty
Convertxtodvd Burning Mkv files with Sub
By alicy in forum Authoring (DVD)Replies: 6Last Post: 31st Aug 2010, 23:29 -
Convertxtodvd Burning problem
By alicy in forum Authoring (DVD)Replies: 8Last Post: 18th Jan 2010, 14:36 -
Converting/Burning With ConvertXtoDVD
By Teac23 in forum Newbie / General discussionsReplies: 2Last Post: 20th Sep 2009, 22:24 -
Convertxtodvd burning problem
By kulkul in forum Newbie / General discussionsReplies: 3Last Post: 3rd Jun 2009, 20:24 -
Problem with converting RMVBs to DVD with ConvertXtoDVD. Please help!
By Centropolis in forum Video ConversionReplies: 1Last Post: 17th May 2007, 23:23
