I'm trying to burn a disc in dvdstyler after adding a menu. The problem I'm running into is that it's taking a long time to burn to disc.Like more than 3hrs. Making an ISO takes this long too. I have a one button menu and a mpeg movie(120min long) I edited together using video edit master. Is this regular?
If the movie isn't DVD compliant, or if DVD Styler is trying to re-encode the video anyway, then yes.
First, look for something int he preferences to tell DVD Styler not to re-encode compliant video.
Next, confirm that your mpeg file is
a) DVD compliant
b) Matches the settings of your DVD projectRead my blog here.
Was I supposed to get soundforge 10 with Vegas 9.0?
By solarblast in forum AudioReplies: 0Last Post: 13th Mar 2011, 23:50 -
Cut Assistant not working the way it's supposed to
By jeanmarc in forum EditingReplies: 3Last Post: 3rd Dec 2010, 05:47 -
What maximum speed to burn DVD I supposed to go with ?
By mahogany in forum Newbie / General discussionsReplies: 3Last Post: 26th Aug 2010, 00:42 -
Supposed copyright blocking transfer
By sydman in forum ffmpegX general discussionReplies: 2Last Post: 9th Jul 2008, 01:25 -
My videos play at a different resolution than they are supposed to?
By darkzero297 in forum Newbie / General discussionsReplies: 3Last Post: 14th Aug 2007, 15:00
