I am having the worst time over here. Something got messed up with autogk so i uninstalled it now im trying to reinstall it and im getting an error " error opening file for writing: "c:\windows\system32\vobsub.dll" hit abort to abort retry or ignore...what should i do i dont know what this file is i tried to install vobsib alone outside of autogk and tells me the same thing...?
Are you using Vista X64 OS? In that case read my recent post, “rant”. I tried various methods to install on my computer, run through administrator, command line, different versions, turning off UAC; I only met partial success, no extras, i.e., DirectVobSub Configure, VobSub Configure, VobSub Cutter, VobSub Joiner.Originally Posted by carlos28355
https://forum.videohelp.com/topic369338.html
TS -
thanks for responding i have rebooted a couple times and im using winxp sp3 im just gonna keep trying i had it installed just fine before? so i dunno
ok so finally it installed i just kept rebooting and unstalling the failed attempt. so i will see if it works this time...thanks
so far so good! just typing loose forum ends here thanks again for your suffestions!
Vobsub freezes when installing and selecting the directory for virtualdub
By toprun91 in forum SubtitleReplies: 3Last Post: 9th Dec 2016, 10:40 -
Installation error
By johnsonk in forum ffmpegX general discussionReplies: 2Last Post: 14th Aug 2009, 12:05 -
Installing VobSub in Vista X64
By ks47 in forum SubtitleReplies: 2Last Post: 16th Jun 2009, 03:07 -
Installing a Printer with No Installation Disk?
By The Monkees in forum ComputerReplies: 1Last Post: 10th Mar 2008, 23:38 -
Installation error -
By ruggerjvd in forum ffmpegX general discussionReplies: 4Last Post: 12th Nov 2007, 10:06
