I cant get this file to stream or even show up on my xbox 360 im putting all my dvds onto my comp and this one is giving me problems...any suggestions? thanks
General
Complete name : I:\My Videos\My Movies\Anime\Berserk.avi
Format : AVI
Format profile : OpenDML
File size : 5.63 GiB
Duration : 9h 50mn
Overall bit rate : 1 367 Kbps
Writing application : AVI-Mux GUI 1.17.8, Aug 30 2008 12:36:58
Video
Format : MPEG-4 Visual
Format profile : Streaming Video@L1
Format settings, BVOP : Yes
Format settings, QPel : No
Format settings, GMC : No warppoints
Format settings, Matrix : Default (H.263)
Codec ID : XVID
Codec ID/Hint : XviD
Duration : 9h 50mn
Bit rate : 1 235 Kbps
Width : 640 pixels
Height : 480 pixels
Display aspect ratio : 4/3
Frame rate : 23.976 fps
Resolution : 24 bits
Colorimetry : 4:2:0
Scan type : Progressive
Bits/(Pixel*Frame) : 0.168
Stream size : 5.09 GiB (90%)
Writing library : XviD 1.2.0.dev47 (UTC 2006-11-01)
Audio
Format : MPEG Audio
Format version : Version 1
Format profile : Layer 3
Codec ID : 55
Codec ID/Hint : MP3
Duration : 9h 50mn
Bit rate mode : Constant
Bit rate : 128 Kbps
Channel(s) : 2 channels
Sampling rate : 48.0 KHz
Resolution : 16 bits
Stream size : 540 MiB (9%)
Alignment : Aligned on interleaves
Interleave, duration : 625 ms (14.98 video frames)
Interleave, preload duration : 216 ms
Writing library : LAME3.97
Encoding settings : -m s -V 4 -q 2 -lowpass 17 -b 128
lol ya its along file i didnt know the 360 had restrictions...thanks for the info (;
stream xvid to xbox360
By sdvideohelp in forum Video Streaming DownloadingReplies: 11Last Post: 10th Feb 2012, 09:32 -
Trying to get .iso to stream to my xbox360 with VLC
By drifter666 in forum Video Streaming DownloadingReplies: 8Last Post: 28th Mar 2011, 00:50 -
For some reason comp wont recognize all computers on University network
By ryangarfield in forum ComputerReplies: 19Last Post: 2nd Apr 2009, 01:29 -
Possible to stream m2t files using Windows Media Center (XBOX360)
By vidarmas in forum Media Center PC / MediaCentersReplies: 1Last Post: 3rd Nov 2008, 19:06 -
WMP11 wont stream
By wayneyg in forum Newbie / General discussionsReplies: 18Last Post: 2nd Jun 2007, 04:09
