I just upgraded to JVC GY-HD100 (from a DV cam) to record and stream (live) Church events. At the moment I can only do this in DV mode since my streaming software (windows media encoder) can't handle HDV. Is it possible to record HDV to tape and at the same time capture DV via FireWire? I don't know how to make this work on the JVC.
What's the advantage of shooting in HD if I'm just going to be producing DVDs?
What media types (apart form hard-drives) can be used to burn HD formats?
I don't have a JVC, but what you're attempting to do sounds like alot of work. You can't just convert the HDV, or just encode to DvD from the HDV, straight?Originally Posted by RodKNicer DvDs since it's a nicer source. It would justify encoding to higher bitrates in this case to obtain some of the source sharpness available transferred to the final encode (DvD) whereas in DV source there wouldn't be as much of that.Originally Posted by RodKThe typical answer would be blu-ray discs, and that's what you'll want to do with them in the future.Originally Posted by RodK
If this content is important enough I'd say keep the source in HDV. Find a way to store it with hard drives today. You'll be glad you did since you will want this encoded to a higher quality format like blu-ray in the near future when it should be much more common.I hate VHS. I always did. -
That would be camcorder model specific. Ask JVC if it isn't in the manual.Originally Posted by RodK
Alternate is record HDV and capture standard def S-Video/audio to Windows Media Encoder for streaming.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
the camera should have a separate setting in the menu for playback output - HDV or DV over firewire - to allow in-cam conversion. but, it may just be for playback not live streaming.
I like the idea of recording in HDV and capturing standard def S-Video/audio to Windows Media Encoder for streaming. Of course the price of this is storage.
JVC GY HD111 - HDV Format - Problem in tape-less Recording on Vostro1014
By aucksy in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 49Last Post: 8th Dec 2010, 12:34 -
CS3 HDV Export to tape marathon/firewire nightmare
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 8Last Post: 2nd Aug 2010, 12:34 -
Can't capture from HDV tape!
By frlane in forum MediaReplies: 8Last Post: 2nd Jul 2009, 16:43 -
Capture from JVC GY HD100 camera
By videopetur in forum Capturing and VCRReplies: 0Last Post: 14th Jan 2009, 19:28 -
HDV tape stock recommendations
By kippard in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 15Last Post: 20th May 2008, 16:52
