Hey all, looking for any help or advice on this matter.
Got an old computer with a 7600 GS 512meg that has the 7 pin S-video out.
I connected a regular 4 pin S-video cable from it to my Sharp LCD (About 4 years old) and the colors were fine, however the picture was off, images blurred etc.
So I went and bought some gold plated component cables (30 bucks at walmart, phillips cables) and used the 7 pin s-video to component dongle that I got with my new 4770's, and now the picture is crisp, but all the colors are green.
No purples either, just pinks.
I fiddled with the color settings (nvidia software) for a long time to try and balance then, even the colors on the tv (luckily each input on the tv has it's own settings) and I just can't get the colors to balance at all.
Any thoughts or ideas? Thanks!
	You're using an adapter from your 4770 with the 7600 GS? Are you sure the pins are the same? There is no universal standard for those 7 pin DIN to s-video/component/vga adapters. Graphics card manufacturers change the pins around all the time. The default color settings on your TV should have been close to correct.
  Laptop connected to PC-screen resolves in red glow on colorsBy petani in forum Newbie / General discussionsReplies: 2Last Post: 26th Oct 2009, 17:07
  LCD TV, when playing DVD turns green after 20 min of play...????By boston_012 in forum Newbie / General discussionsReplies: 12Last Post: 9th Aug 2009, 22:11
  PC connected to LCD TV | Graphic Card Temp > 55 | TV Screen BlinkingBy anoopaythala in forum Media Center PC / MediaCentersReplies: 3Last Post: 27th Feb 2009, 16:23
  HTPC connected to LCD TV - how to resize image on TV???By superfuzzy in forum DVB / IPTVReplies: 4Last Post: 12th Dec 2008, 18:45
  Displaying Photos on an LCD Monitor or LCD TVBy jbsiegel in forum DVB / IPTVReplies: 3Last Post: 25th Sep 2007, 13:29
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
