Downloaded a movie which has ext: .divx. But all the software I tried none will open it. Tried VirtualDub, Subtitle workshop, Windows Media player, Media Player Classic, VLC Media Player, Avidemux, MediaInfo, GSpot. Can you help pl?
Closed Thread
Try Divx Player.
If it can't play it then it's probably not any video. How big is the file?
You can probably change the extension to .avi and have it work in everything you mentioned. Its unlikely that whoever created the video used any of the Divx extensions (ie. menus...). And, even if they did, once renamed to .avi the only thing you'll lose is that compatibility. No big loss.
Have a good one,
neomaine
NEW! VideoHelp.com F@H team 166011!
http://fah-web.stanford.edu/cgi-bin/main.py?qtype=teampage&teamnum=166011
Folding@Home FAQ and download: http://folding.stanford.edu/
The file could be corrupted and that's why it won't play. If you got this via Bit Torrent, that's probably what happened.
Hollywood has been known to deliberately make bad files available for download. This could also be what has happened if this is an American movie.
You can try renaming it to .avi as neomaine suggested, but your problem is most likely one of the 2 things I mentioned.
Tks guys. Divx player didn't succeed either...it said Does not appear to contain a video track...
I think that jman98 is right..I downloaded it via Bit Torrent and maybe it is corrupted. The movie is The Deep fyi.
As a last resort I'll try to change it to .avi and see what happens.
You are in breach of the forum rules and are being issued with a formal warning.
/ Moderator redwudz
Just buy the movie. It's probably in the bargain bin.Originally Posted by bahnan
You get what you (don't) pay for.
downloaded SVCD2DVDv2.5.zip won't open
By bobarnett in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 6th Aug 2011, 15:48 -
downloaded video wont play in my dvd player
By KingRich70 in forum Newbie / General discussionsReplies: 17Last Post: 10th Jan 2011, 18:52 -
ProRes 422 (LT) 4.29GB wont open
By RenderFi in forum MacReplies: 8Last Post: 11th Dec 2010, 09:54 -
Help the prgramme wont open!!
By amber123 in forum SVCD2DVD & VOB2MPGReplies: 6Last Post: 23rd Apr 2009, 06:51 -
.mov wont open in quicktime
By lonewolfsas2k4 in forum Newbie / General discussionsReplies: 1Last Post: 4th Nov 2007, 11:25
