Hi,
Sorry if these have been asked before, or are not relevant.
1. Is WinDV still the best way to capture from camcorder -> digital?
I personally do find it 10/10, but just wondering if there are better tools I should try.
2. Does using WinDV with a slow PC or large PC make any difference? I mean in terms of the video quality.
Thanks!
1 Yes. Assuming all you want is to capsfer the video.
2 Makes no difference, as long as the computer is at least fast enough to keep up with the capsfer (no dropped frames). The video capsferred is the same quality as what's on the tape."Shut up Wesley!" -- Captain Jean-Luc Picard
Buy My Books -
All WinDV will do is capsfer. Other software can also process the video while capsferring to do things like embed the timecodes. Editing isn't done in WinDV, but the resulting DV-AVI file can be compatible with most editing software. Some editing software include a capsferring option, which may or may not be as good as WinDV.
Buy My Books
Should I use WinDV?
By tygger in forum Capturing and VCRReplies: 19Last Post: 6th Jan 2012, 18:23 -
Windv to harddrive
By runnernorth in forum Capturing and VCRReplies: 3Last Post: 12th Jan 2010, 05:36 -
WinDV
By kippard in forum Capturing and VCRReplies: 3Last Post: 8th Apr 2008, 00:43 -
Windv Scheduler
By ScottEslick in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 27th Jan 2008, 22:46 -
Error with WinDV ?
By Zhuge Liang in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 13th Jul 2007, 03:47
