I am working on making a photo slideshow dvd. I used a program from arcsoft to create the slideshow. It did a fantastic job. I was able to create chapters and other effects. It saved it already as dvd files. All I have to do is burn it to a dvd and it works fine. The slideshow starts right up.
However, I would like to create a dvd menu to go with it. Like a play all, or go to certain chapter. I am having problems finding the right program (preferrably free) and knowledge. Can anyone help?
You need a dvd authoring application, if you want free ones you can use guifordvdauthor or dvdstyler. But I'm not sure how you will be able to import your current dvd, if it's just a video clip you can easily add it but if not it will be MUCH harder...maybe using dvdremake pro but it's not free.
My DVD slideshow GUI project file has disappeared.
By sjonas in forum Newbie / General discussionsReplies: 7Last Post: 19th Oct 2009, 13:35 -
Project Settings Window in DVD slideshow GUI
By tit4tat in forum Newbie / General discussionsReplies: 5Last Post: 3rd Mar 2009, 10:04 -
Help Neeeded For DVD Project. Extract DVD Menu For Use In Personal Project
By sephiros in forum Authoring (DVD)Replies: 2Last Post: 5th Nov 2008, 13:49 -
Want to Create Slideshow DVD to show on My HDTV
By 1deciple in forum Newbie / General discussionsReplies: 0Last Post: 7th Jul 2008, 16:54 -
How to create IFO &BUP file for DVD menu[have menu vob]
By Aliyans in forum Authoring (DVD)Replies: 3Last Post: 28th Dec 2007, 12:36
