I captured my movie using Virtual Dub, and it created 12 segments. I then ran each segment through some filters (poor input quality - old Beta tape), then ran each segment through TMPGEnc for encoding, and finally used TMPGEnc to merge all the mpg segments to one single file. The problem is there is an audio pop between each segment in the final file. I don't really see a video problem, but I can definately hear an audio pop. I can probably avoid the problem by using the Frame Server to feed TMPGEnc, but why does the audio pop occur? Not using the Frame Server means a power loss only causes segement re-encode, rather than the whole movie. Did I do something else wrong?
As an audio producer, I work with digital audio all day. This sounds like the edit is happening where the audio does not zero-cross. If you've ever used a waveform editor, when you look a waveform, there is a line in the middle called the 0db line. The best possible place to cut audio is where the waveform crosses this line. If not, you have the possibility where one waveform ends well below the 0db and the next starts above the 0db line, then instead of having a smooth waveform, you have a big jag which causes an audible pop.
Hope this helps!
clicks and pops in very old VHS tape
By snafubaby in forum Capturing and VCRReplies: 0Last Post: 27th Sep 2009, 04:55 -
Help:VDUB:CANNOT APPEND SEGMENT segment has a different number of streams
By lil_Dee in forum EditingReplies: 9Last Post: 23rd Jun 2009, 09:16 -
Ticks and Pops in Audio
By punkyb in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 22nd Jun 2009, 16:29 -
Pops, Clicks when ripping DVD
By coyotewrw in forum DVD RippingReplies: 1Last Post: 14th Nov 2007, 19:57 -
MP3>ac3 pops and clicks
By joesphroth in forum Authoring (DVD)Replies: 0Last Post: 6th May 2007, 16:18
