I see some like this where even the non-HQ video looks really good. Any idea why?
http://www.youtube.com/watch?v=uU1epjkUfMo&feature=channel_page
	Looks like 4:3 standard DV def (to flash) to me. Do I need to watch the whole thing?
 The audio quality really sucks (not the performer).Recommends: Kiva.org - Loans that change lives.
 http://www.kiva.org/about
	Compare to thisOriginally Posted by edDV
 http://www.youtube.com/watch?v=U-lt3vVA-4I&feature=channel
	Youtube re-encodes everything, so if you send a higher quality video, the end result will be higher quality
 Also, there are differences in the two; there are more scene changes (usually require IDR-frames) and motion in #2 , both these require more bitrate to look the same "quality", therefore overall quality is worse in #2 for a given bitrate limit (I think YT limits to ~500kb/s)
 Also, #2 is using an older spec and ~200kbps 320x240, #1 is using ~500kbps 480x360, so they are apples and oranges when comparing
	#2 has been over compressed. Recommends: Kiva.org - Loans that change lives.
  Video is blurry on computer but clear on HDTV, how can it happen?By Bencuri in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 55Last Post: 26th May 2012, 12:48
  What does cable-in-the-clear means ?By SingSing in forum Video Streaming DownloadingReplies: 1Last Post: 31st Mar 2010, 21:14
  How to get max clear stills, when pause a video - should I deinterlace??By vantechmag in forum EditingReplies: 2Last Post: 11th May 2009, 18:55
  YouTube video...super clearBy MaDmiZe in forum Off topicReplies: 4Last Post: 21st Feb 2009, 06:12
  Removing Noise from Video and Making it clearBy AjnabiZ in forum RestorationReplies: 27Last Post: 25th May 2007, 16:58
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
