I just have 2 questions:
1) Do you have to use special disks (cd's) to make a VCD?
will regular blank cd's work?
If so, which ones are the best or the cheapest?
2) Can you burn copy of a VCD (from VCD to VCD) w/ Adaptec cd creator 4.0 or do you have to use the 5.0 version?
Kira![]()
upnsroswell@cs.com
Watch ROSWELL on the UPN Tuesday Night after Buffy the Vampire Slayer at 9 pm
I believe adaptec 4.0 will do vcd, but its been awhile since I used it. Nero is a better application for doing vcd, but it doesn't work with adaptec installed if I remember correctly. Anyway for the answer to your other question. Yes regular blank media will work fine for vcd. Pretty much anything though I would avoid imatition and acer. Verbatim makes a pretty good one. As well as does memorex, though avoid their off brand name dysan.
1. Regular CD-R discs will work.
2. I don't know if you can copy disc to disc with Easy CD Creator, but any proggy that can do a DAO copy will be able to copy VCDs (e.g., Nero, CDRWin, Clone CD).
Regards.Michael Tam
w: Morsels of Evidence
Need your help on some very basic video questions
By Booklet in forum Newbie / General discussionsReplies: 3Last Post: 6th Oct 2009, 12:12 -
By Dan K in forum Newbie / General discussionsReplies: 17Last Post: 2nd Jan 2009, 16:59 -
Some Basic HD Television Questions
By Maikeru-sama in forum Newbie / General discussionsReplies: 29Last Post: 6th Jul 2008, 11:02 -
Basic FFMpeg Questions
By Maikeru-sama in forum Video ConversionReplies: 8Last Post: 7th Jun 2008, 09:33 -
VHS to DVD (basic questions)
By BPH2002 in forum Video ConversionReplies: 5Last Post: 2nd Jan 2008, 09:32
