Hello, everyone.
I used many times the guide " http://www.ryan.com.br/virtualdub_en.htm " but lately I can no more.
When I execute that link it appears
Forbidden
You don't have permission to access /virtualdub_en.htm on this server.
Additionally, a 404 Not Found error was encountered while trying to use an ErrorDocument to handle the request.
Apache/2.2.11 (Unix) mod_ssl/2.2.11 OpenSSL/0.9.8i DAV/2 mod_auth_passthrough/2.1 mod_bwlimited/1.4 FrontPage/5.0.2.2635 Server at www.ryan.com.br Port 80
What can I do to heve acess to that guide?
Thanks.
Save the page locally:
Using Firefox: go to the page when it's working then select File -> Save Page As. At the Save dialog select Web Page, Complete. Pick a local location and save.
From IE: go to the page when it's working then select File -> Save As. Set the Save As Type to Web Archve, Single File (*.mht), or Web Page Complete. Then save. -
I clicked on the link and went straight through to the guide
How to recode an AVI with Virtualdub
Brazil doesn't block Portugal, does it?
I know that i can't access certain content on UK sites, but whole pages aren't blocked.
Have you tried different browsers?
Maybe it was temporary (maintenance, server change, etc.) -
Thanks Supreme2K and Jagabo.
It's strange I don't manage to obtain that page since 6 months ago. Before I always managed.
With the link Jagabo sent me I already got the guide.
Cheers. -
404 usually means "the file doesn't exist at that location". If the server is blocking access, I think it's supposed to give a different return code.Originally Posted by Supreme2k
I live in the USA and I can access the site. I used to work for a company that had customers in Brazil and I can tell you only that things are "different" in Brazil. I used to see Brazilian banks block web access from "non-Braziilan" websites. The only problem was that in our case Philips, the Dutch multinational company, was one of our customers and they couldn't access some Brazilian banking websites because the banks' software looked up who registered the IP address range, saw it was registered in the Netherlands, and blocked it. So this dumb ass ryan.com.br web provider probably is blocking access outside of Brazil. The question is - Why are Americans getting through? A failure in the blocking program? Or do they ONLY block Portugal? Is the blocking of Portugal a mistake? I can answer none of these questions. -
i could open it. if it doesn't work for you, you might wanna try http://web.archive.org/web/20071107073145/http://ryan.com.br/virtualdub_en.htm
RiData - what happened to them?
By akkers in forum Authoring (DVD)Replies: 4Last Post: 23rd Apr 2012, 11:24 -
Crossover cable / AC Ryan PlayOn
By ringo12 in forum Media Center PC / MediaCentersReplies: 3Last Post: 9th Nov 2010, 08:38 -
AC RYAN DVR HD,I need help with the recording system
By densleyporter in forum Newbie / General discussionsReplies: 1Last Post: 3rd Nov 2010, 10:15 -
AC Ryan : Toggle betwwen PAL & NTSC for composite
By warresg in forum Media Center PC / MediaCentersReplies: 0Last Post: 10th Jul 2010, 12:46
