Hey Guys...
to say i need help is an understatement!! iv read the whole of google trying to sort it out, but nothing..
the problem i have is when i install Easycap 2.0 (DC-60) it creates a new High Speed Lan Connection (Lan/High Speed Connection 3 / Connected / Microsoft Tv / Video Connection)
and it completely stops any internet connection i get, if u unplug the easycap, the connection is fine, if i restart the computer, the lan connection goes away, but if in plug it in, i cant use the internet & so on...
someone said disconnect it in devices? but its not in there..?
does anyone have any advice!! plz..............
	I do not have one so this is really a wild guess.
 The EasyCap uses USB right ? and any device on the usb bus will compete with all other usb devices.
 It may be deliberately disconnecting the internet to remove that competing device and give more resources for the capture. After all, you would not want to be surfing etc while you are capturing video. At the very least, the internet use is using your hard drive (caching etc) and that in itself could cause capture problems.
	thanks for the reply, my internet is connected via ethernet..
 the problem is i do need to be on the internet as i want to stream my game broadcast to justin.tv???
  easycap helpBy 11wesley11 in forum Newbie / General discussionsReplies: 0Last Post: 13th Apr 2010, 17:08
  Easycap Help !By ellisharris in forum Capturing and VCRReplies: 0Last Post: 20th Mar 2010, 11:21
  easycapBy neko_chan in forum Capturing and VCRReplies: 1Last Post: 30th Apr 2009, 04:41
  easycapBy stusy in forum Newbie / General discussionsReplies: 0Last Post: 27th Feb 2008, 18:02
  Kaspersky Internet Security 7.0 installation Conflicting with Internet ExpBy Krelmaneck in forum ComputerReplies: 2Last Post: 5th Oct 2007, 04:36
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
