Hi all, i'm a newbie.
Recently i downloaded avi movie and i want to convert to mpeg(vcd).
Some are in ffdshow codec and in xvid.
I try to convert avi to mpeg with subtitle using mainconcept & boilsoft, and it works when it is in ffdshow.
But i cannot make it when it is xvid.
Is there any way to convert avi in xvid codec to mpeg with subtitle?
Please advise. Thanks.
ffdshow handles multiple codecs, including XVid. You can always try opening the "VFW configuration" and "Video decoder configuration" options in ffdshow's Start menu folder, click on 'Codecs' in the left-hand pane, then enable Xvid in the right pane (set the dropdown to 'libavcodec'), and see if that helps.
If cameras add ten pounds, why would people want to eat them? -
I just downloaded and installed K-Lite Codec Pack 4.90 and uninstalled previous 3.45.
I followed your step, and I tried to open the avi movie. Now the movie is running in ffdshow codec, previous was in xvid.
Did the converting and the result is mpeg with subtitle, as I want. This is great. Thank you very much for solve this. Greets to Ai Haibara
Convert from MKV to AVI (mpeg-4 codec) + add subtitle to the video file
By kovacic_10 in forum SubtitleReplies: 3Last Post: 19th Feb 2011, 17:38 -
Adding subtitle to xvid without increasing file size of the .avi?
By Kromgol in forum Newbie / General discussionsReplies: 3Last Post: 19th Jul 2009, 12:03 -
convert 2cd Xvid to 1cd xvid Avi
By mehargags in forum Video ConversionReplies: 6Last Post: 14th Apr 2008, 10:55 -
Convert mpeg-2 to xvid while cutting commercials...
By swishbish33 in forum Video ConversionReplies: 5Last Post: 25th Oct 2007, 18:10 -
avi or xvid file with switchable subtitle to dvd 5
By lovemychemical in forum SubtitleReplies: 3Last Post: 16th Jul 2007, 09:28
