Results 1 to 14 of 14
    Dec 2007
    Hi. I have a mpeg movie of a play that was filmed in a gym. I am wondering if there is any software out there that may be able to pull up voices talking and drown out the echoes of the gym. I know its a longshot. Thanks.
    Apr 2004
    Miskatonic U
    A very long shot. Your best bet would be to play around with the equaliser settings and hope you can suppress the worst of it without killing everything else. I don't know of any filters that will do what you are asking. Audacity has an EQ, as do all decent audio editors. If you have an editor that supports VST you might look at the PushTec filter, which works along the same line an an EQ filter, but with a smarter interface for working across ranges.
    Read my blog here.
  3. Member AlanHK's Avatar
    Apr 2006
    Hong Kong
    Which includes Audacity: http://www.audacityteam.org/vst/
    Apr 2004
    Miskatonic U
    Has Audacity's VST support improved lately ? I found it's inability to correctly render VST plugin interfaces meant that many simply could not be used in any meaningful way. The stability of the VST interface was also questionable. It would be nice to hear that it had improved enough to warrant using.
    Read my blog here.
  5. Member AlanHK's Avatar
    Apr 2006
    Hong Kong
    I admit I've never used it; I just noticed it was a feature.
    It's "version 1.1 - released March 3, 2007"
    The Audacity forums would be the place to ask.
  6. Member netmask56's Avatar
    Sep 2005
    Sydney, Australia
    If there is a bit of acoustic space or separation between the voices and the background room rumble/reverb you could roll off the bass a tad and apply a little bit of midrange boost to highlight the voices followed by 3 to 4 db downward expansion. Most "noise gates" have this ability like in the Waves Ltd range of plugins.
    Aug 2008
    The Moon
    No, Audacity still does not support VST guis, which is one reason why I moved elsewhere. Even Wavosaur (freeware) supports VST guis so I don't know what Audacity's problem is.
    blaqlion22, give Reaper a whirl, maybe it's built-in ReaFir plugin can help suppress the unwanted echoes.
  8. Member AlanHK's Avatar
    Apr 2006
    Hong Kong
    Audacity is Open Source, VST's are proprietary.
    Originally Posted by Audacity
    Because of licensing issues, VST support must be kept separate from Audacity. This "VST Enabler" is mostly open-source, but the source code to Steinberg's VST SDK is required, and this must be downloaded from Steinberg separately.
    So VST support is not well integrated.
    Wavosaur is currently free, but not Open Source.
    Aug 2008
    The Moon
    Heh? That doesn't make sense. Is "open source" restrictive? Then why not just call your bloody software "freeware" instead of "open source"? Ridiculous.
  10. Always Watching guns1inger's Avatar
    Apr 2004
    Miskatonic U
    The licensing issues are with Steinberg, which is not free or open source, and not with Audacity. Audacity cannot include Steinberg's libraries or code in their own project.
    Read my blog here.
    Aug 2008
    The Moon
    Yeah but how then does Wavosaur and Kristal and all those other free audio engines get away with it?
  12. Always Watching guns1inger's Avatar
    Apr 2004
    Miskatonic U
    They don't give away the source code
    Read my blog here.
  13. Member AlanHK's Avatar
    Apr 2006
    Hong Kong
    "Freeware" is not "open source".
    Look it up.
  14. Video Restorer lordsmurf's Avatar
    http://www.digitalfaq.com/guides/video/restore-audio-soundforge.htm
    http://www.digitalfaq.com/forum/showthread.php/pre-processing-audio-1428.html
    SoundForge and/or Goldwave would do it.
    Echos can be impossible to remove.
    Maybe iZoTope, but it can take forever. Almost like NeatVideo.
