I've been doing this for years with no problem. I use my VCR and AVDC 100 for capturing video. Last week, my tv video got very bad....not sharp...very grainy. I switched the vcr to another one I had in storage and the tv picture cleared up instantly. However, the quality of my captures is very poor. I'm thinking there's something wrong with the output jacks on the old (ancient) vcr. I'm using a brand new wire so that's not the problem. I've been looking online for a new vcr with three output jacks in the back but not having any luck. Is there a better solution using a dvd recorder perhaps? Is it possible the canopus is at fault? Thanks.
To check the Canopus, connect it to a clean signal (e.g. a cable box or DVD player with home made disc).Originally Posted by BonnieW88Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
I tested....it's not the canopus. I just found an inexpensive dvd recorder on amazon. Got very good reviews....I'm going for it. Thanks for helping me narrow down my problem.
Phooey! The dvd recorder I was looking at has only component jacks. I was hoping it would connect to my dish the same way my vcr did.....in from dish, out to tv with coaxial cable. Does anyone know of a unit that would work for me?
Video Encoding, MeGui + AviSynth fuzzy picture
By shorto in forum Video ConversionReplies: 8Last Post: 21st Mar 2010, 18:07 -
Black Fuzzy Screen
By hfullerton@bcsd1.net in forum Newbie / General discussionsReplies: 1Last Post: 2nd Oct 2009, 13:16 -
Nokia N73 fuzzy lines on the video from Nero Digital
By fdonline in forum Portable VideoReplies: 1Last Post: 17th May 2008, 04:00 -
.mov to flash comes out fuzzy!
By crocwatcher in forum Newbie / General discussionsReplies: 1Last Post: 22nd Jan 2008, 04:16 -
channel 5 on hdtv it comes fuzzy
By jamz09 in forum DVB / IPTVReplies: 2Last Post: 9th Jun 2007, 05:38
