So, all I want to do is take an mpeg that I have, make it grayscale, and then save it that way, BUT I want to keep the original quality... So far, all the free editors I've tried don't keep the quality.
I guess my question is this: What's a free program that can make my mpeg grayscale, but will keep the original quality after the fact?
Any help would be great, thanks!
-Boosh
You have to re-encode. If you use lower settings you will lose quality. If you use the same settings you risk using quality, depending on what they are.
I would try AVI Demux first, but use higher bitrates than the source.
Otherwise I would use avisynth and HCEnc. It is trickier, but the quality should be better.Read my blog here.
Best quality DVD output software for maintaining photo quality
By P_Erickson in forum Newbie / General discussionsReplies: 20Last Post: 21st Apr 2012, 22:30 -
FFmpeg and quality of the output video
By Vidameker in forum Video ConversionReplies: 2Last Post: 26th Jan 2010, 20:46 -
Will there be a difference in output quality?
By ingeborgdot in forum EditingReplies: 55Last Post: 21st Sep 2008, 18:41 -
Output quality and settings of DVDShrink
By src2206 in forum DVD RippingReplies: 21Last Post: 23rd Jan 2008, 06:38 -
how to get best output quality ?
By korsion in forum Authoring (DVD)Replies: 11Last Post: 25th Jul 2007, 20:41
