hi
i am new here and my information is limitted
is there a cinverter to convert avi to mpeg 2 without lose?
i used to use allok video spliter and the output format was very good but since i worked on another pc the output format was rubbish......when i checked the output file its parameters was like this
Format : MPEG Video
Format version : Version 2
Format profile : Main@Main
Format settings, Matrix : Default
Duration : 34s 520ms
Bit rate mode : Variable
Bit rate : 8 183 Kbps
Nominal bit rate : 8 000 Kbps
Width : 720 pixels
Height : 576 pixels
Display aspect ratio : 1.111
Frame rate : 25.000 fps
Standard : NTSC
Colorimetry : 4:2:0
Scan type : Interlaced
Scan order : Top Field First
Bits/(Pixel*Frame) : 0.789
where my origional file was
Format : MPEG Video
Duration : 13s 360ms
Bit rate : 4 255 Kbps
Nominal bit rate : 5 184 Kbps
Width : 720 pixels
Height : 576 pixels
Display aspect ratio : 5/4
Standard : PAL
Colorimetry : 4:2:0
Scan type : Progressive
Bits/(Pixel*Frame) : 0.410
from it i concluded that both the scan type and video type (PAL and NTSC) has something to do with the quality
i use allok video splitter 1.8.0 and i cant find the setting
so please if anyone knows how to produce pal and Progressive Scan typed tell me
thank you in advance
Wouldn'y VirtualDub's frameserver work well here?
There are no problems - only chances to excel.
-- Unknown -
MPEG is a lossy compression format. It's impossible to convert anything to MPEG without some loss of quality. At high bitrates the losses my not be very visible though.
The stats of your source video say it's already MPEG 2 (MPEG 2 in AVI is rather unusual -- are you sure it's really an AVI file?). You should be able to simply remux that into an MPG program stream container with AviDemux. This would lead to no change in quality. -
the second infos are for the clip converted on another pc so i posted it as a comparsion only
however i have found an excellent program called all video splitter but the only problem is the output file has a sample rate of 44 KHz instead of 48 KHz although the origional file has 48 khz
can someone please explain this to me -
Try good mpeg2 encoders like tmpgenc plus or tmpgenc xpress or hcenc with a gui like HCbatchGUI or AVStoDVD or AVStoMPEG.
WMV to MPEG2 converter
By siluet in forum Video ConversionReplies: 1Last Post: 5th Oct 2008, 13:13 -
Best quality (Not speed) Converter for miniDV to Mpeg2
By AussieHusky in forum Video ConversionReplies: 5Last Post: 2nd Nov 2007, 01:54 -
Best AVI -> MPEG2 converter? (Freeware??)
By w@ntonsoup in forum Video ConversionReplies: 3Last Post: 13th Oct 2007, 23:58 -
JVC GZ-HD7 NTSC - i lose frames when compressing to AVI
By Wookiss in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 11Last Post: 10th Jul 2007, 08:18 -
720x576 avi files lose their aspect ratio when played on DVD player
By tzikeh in forum Authoring (DVD)Replies: 1Last Post: 24th May 2007, 02:47
