nope. But the code has to match in terms of paths, filenamesOriginally Posted by DaneClark
Results 31 to 44 of 44
The only problem now is that the file size is coming out WAY too big.
How much is way too big?
What settings for video & audio did you use?
For similar quality, expect it to be bigger -
for me, "too big" is anything over 500 MB or so.Originally Posted by poisondeathray
How big was the original wmv? what was the video & audio bitrate?
If you need a precise size, you need to use a 2pass encode
What xvid settings did you use? stock settings with q=3? -
Use a higher quant value. So if you used q=3, try q=4. Or use 2pass for exact size
Also, you should use DV-AVI to export out of Movie Maker, then deinterlace (if interlaced) and use that to encode to to xvid. Using WMV out of Movie Maker is more lossy
If your footage was noisy, consider denoising it (noise eats up bitrate)
If your footage was shaky, consider stabilizing it (shaky movement eats up bitrate) -
The video bitrate of the original file was 1635 kbps. The audio bitrate was 169 kbps.
The DiVX setting were set to "1-pass quality base" with a target quantilizer of 3 -
How do I de-interlace? And I would much rather encode to DiVX because XVID always gives me problems. Will de-interlacing reduce the file size while keeping the quality close to original?
You would deinterlace only if your source was interlaced. What were your original source files?
Right now virtualdub is saving my file at q=4, and it looks like the file size is going to be reasonable. Now, how to I de-noise incase it comes out too noisy?
Thanks for your help everyone. I think I've found everything I needed to know.
It's highly unlikely your WMV source is interlaced. And if it was you'd be complaining about weird lines in your video.
Help! Converting WMV to MP4 without losing quality?
By videojam in forum EditingReplies: 9Last Post: 25th Mar 2012, 10:00 -
converting blu-ray to mkv without losing quality
By Arkadietz in forum Blu-ray RippingReplies: 5Last Post: 3rd Oct 2011, 18:31 -
Converting 3gp file to WMV or AVI without losing clarity
By brketch in forum Newbie / General discussionsReplies: 2Last Post: 18th May 2011, 08:01 -
Losing all the quality converting 720p
By TheDizzle in forum MacReplies: 1Last Post: 25th Jan 2009, 13:30 -
Converting .WMV to .MPG and losing audio/picture
By frenchdb in forum Video ConversionReplies: 1Last Post: 29th Jun 2008, 21:42
