I have done research and think I know the answer to my question, but need confirmation.
I OWN the Star Wars Attack of the Clones DVD and want to convert and put it on my Blackberry 8900 with Mobilola Video Studio.
I have converted Revenge of the Sith and numerous other DVD's and no problem.
When I play on my laptop Attack of the Clones has no problem.
When I go to convert it, it defaults to the full audio commentary version.
Is this a failsafe for the manufacturer and if so, why can I convert Revenge of the Sith? It has an audio commentary version too.
Any help is greatly appreciated,
Ken
AnonymousGuest
AnonymousGuest
Thanks,
I will look into that. I am not good at some of this stuff. Will try and ask for help if needed.
Just wasn't sure why one movie was ok and another not.
ken -
This kind of thing happens all the time - be glad this is the first time it's happened to you. It has to do with how the DVD was authored and there's not really anything you can do about that.Originally Posted by rugmankc
The suggestion means that you will create a new DVD, so to speak, on your hard disk that only contains the audio you want and then you will convert that with your Mobillola Video Studio. Of course if Mobilola allows you to select which audio stream it processes (if it doesn't, well, it's kind of crappy) then just pick a different audio stream and eventually you'll get the right one. -
AnonymousGuest
Thanks for the clarification, I'll give it a try.
Mobiola is excellent on audio and video, with this exception.
Ken
How can I add an audio commentary to a dvd?
By artyjeffrey in forum Authoring (DVD)Replies: 1Last Post: 28th Nov 2009, 03:44 -
using VOB2MPG to convert WITHOUT the commentary audio track
By wildrthanevr in forum Video ConversionReplies: 4Last Post: 16th Mar 2009, 11:57 -
removing the commentary audio track from an AVI file with mpeg layer3 audio
By wildrthanevr in forum AudioReplies: 1Last Post: 10th Mar 2009, 01:29 -
Mixing/Recording Commentary into Source Audio
By WakkoBlues in forum AudioReplies: 4Last Post: 23rd Jul 2008, 20:03 -
how to add commentary over dvd audio?
By Denvers Dawgs in forum AudioReplies: 3Last Post: 23rd Nov 2007, 23:58
