Results 1 to 10 of 10
You would not regain any of the image behind that interference.
My suggestion is that you use a crop filter to remove the entire edge where it interferes. You could then re-size that image back to the original width. The image will be a little stretched but should not be too bad. -
10x man. but after i did it in full processing mode the video takes 80 gb because RGB is in default how do i change it so i won't need another conversation
VirtualDub used 'Uncompressed' as the default under the Video/Compression menu.
To get a smaller file size you will have to select a different compression - the ones available to you will appear in the compression list. -
eliqush - Stop using IM slang. Your English is very weak and trying to be cool with stuff like "10x" is really just making you look like an idiot. I can't take you seriously if you insist on saying "10x" and "which 1 2 choose".
You need to improve your English a lot if you want to talk like some damn IM punk here. That first post was horrible.
If you have Xvid installed, choose it. If you don't have Xvid installed, choose MJPEG. And if you say "10x" to this, then you are a complete loser. -
jman98
sometimes it's not worth the trouble of typing anything.
You can teach donkey how to dance and still in the end all you'll get is pissed donkey and your wasted time... -
Since your video is interlaced use the Fill filter to cover the noise with black. What compression codec you choose depends on what you plan to do with the video. Make a regular movie DVD? Make a Divx file? Something else?
Recording VHS to VHS?
By hartshapedbach in forum Capturing and VCRReplies: 5Last Post: 1st May 2012, 18:49 -
Recording NTSC VHS with LG RH397D/RH399D
By VideoVHSDVD in forum Newbie / General discussionsReplies: 1Last Post: 9th Jul 2011, 01:28 -
Vhs to dvd recording
By JAYHAWK1970 in forum Newbie / General discussionsReplies: 4Last Post: 16th Jan 2011, 19:21 -
Question about VHS recording
By gejlvem in forum Capturing and VCRReplies: 1Last Post: 12th Jan 2011, 17:24 -
VHS To DVD Recording errors
By DuBsTaR in forum Newbie / General discussionsReplies: 2Last Post: 14th May 2010, 12:31
