I have Mac OS X 10.3.9. How can I upgrade it to a higher version of 10.4 or 10.5, such as Leopard, without having to buy the software because it's expensive. Please help. Thanks.
	While its true older Macs can use newer operating systems, Apple can be a little much sometimes pushing OS updates that really don't do a heckuva lot more than previous systems (save the flames, I'm talking about "average user" situations). If your Mac shipped with 10.3, its a good idea to go to 10.4 to be more current but jumping to 10.5 isn't necessary, especially with 10.6 bearing down. Either save your pennies for Snow Leopard, and get completely caught up, or check eBay as russkelp suggested for the older 10.4 disc which is usually at a steep discount to 10.5. Once you have the 10.4 disc (most of which are 10.4.3), download the 10.4.8 combo updater from Apple and you're good to go (avoid 10.4.9, it has some bugs with certain Mac models). Unless your software is specifically optimized for 10.5 and later, or you think you must have one of the new window-dressing features, it usually pays to stay one step behind Apple's OS curve while they shake the issues out.
	It's a good idea to check Apple's site for the minimum system requirements for each 10.X.0 upgrade, though. For example, my old faithful G3 iBook meets the minimum requirements for 10.4, but that's more or less about it. And even then, it may not be as well-suited for running 10.4 as it is 10.3.
 I just haven't seen a pressing need to upgrade, to be honest. It's true that a lot of apps no longer support Panther, but... I'm still getting by. If cameras add ten pounds, why would people want to eat them? If cameras add ten pounds, why would people want to eat them?
	coy,
 since according to your specs you are running a PowerPC G5,
 if it's processor is 1ghz or higher, you can run Tiger
 and Leopard ( but I'd recommend upgrading your 512mb of ram
 to at least 1GB in either case).
 While the software updates are expensive if bought retail
 from Apple, there are plenty of deals abound:
 OS X Leopard 10.5 for $99
 Tiger 10.4 Retail DVD $33
 You can also look at education pricing as well...Tiger can still be bought
 from many education channels for around $60 per install dvd set.
 Also, update once you purchase to Tiger 10.4.11, not 10.4.8,
 as it is the last stable system patch for Tiger, and address many,
 many things that will keep your mac current.
 For instance, you cannot run iWork 09 or iLife 08 without 10.4.11,
 Perian runs better in 10.4.11, and with 10.4.11, you can use Toast 9,
 the last pre-Leopard version of Toast.
 For Leopard, I would recommend buy 10.5.0 retail ( it has the widest
 and best Compatible Open Firmware and EFI Firmware set
 for the widest range of PPC and Intel macs to boot from) and then
 patch up via Software update to 10.5.6 ( the most stable
 Leopard update, and the biggest one to fix a majority of Networking
 issues to date)."Everyone has to learn, so that they can one day teach."
 When I'm not here, Where can I be found?
 Urban Mac User
	While I agree 10.4.10 and 10.4.11 offer distinct benefits over 10.4.8, they remain problematic for many users depending on the particular Mac and what applications are installed. OSX is a constantly moving target, the damn thing has rarely ever settled for five minutes in one sedate spot, so updating to the latest rev mostly means you'll be cleaning up after the latest set of glitches. terryj has outlined the situation precisely, if you use any of the software mentioned you'll want 10.4.11. If you haven't installed any significant new software in the last two years, maybe not. And of course 10.5 brings a whole other can of issues with it. Whichever upgrade path you take, the most important thing (besides the additional RAM terryj recommended) is to never apply Apples individual incremental patches: always look for the "combo updater", its a much more reliable installer.
  Mac version of VLC is less functional than the Windows and Linux versionBy HitTheRoad in forum MacReplies: 12Last Post: 30th Oct 2011, 04:48
  Higher Bitrate = Higher Quality? - 20MBPS difference for 1080p fileBy SgtPepper23 in forum Newbie / General discussionsReplies: 4Last Post: 6th Dec 2009, 08:57
  Can I use an upgrade key on Windows 7 with a Full version Download?By terumaru in forum ComputerReplies: 5Last Post: 25th Oct 2009, 08:48
  MediaInfo Mac / GUI version :: Latest: 0.7.5.81By DiegoMax in forum MacReplies: 16Last Post: 31st Aug 2009, 06:15
  Upgrade to iMovie '09, or Try out a New Mac Video App?By wpeterson in forum MacReplies: 13Last Post: 24th Feb 2009, 01:45
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
 Quote Visit Homepage
				Visit Homepage
