1 coax cable going to 2 way splitter 1 coax cable going to cable box then to tv other coax cable goint to another another getting just basic cable, the signal comming from the cable box to tv blinks flikers some times on a few channels & another cable going just to the tv some channels come in really fuzzy. How would I go about fixing the singal so tvs are clear the 2 way splitter is a cheap $5 splitter I was thinking about getting this splitter http://www.yourbroadbandstore.com/product.php?pid=712655 would it fix the singal problem if not what do I need to fix the problem I am am looking for something under $30
Results 1 to 10 of 10
You shouldn't need an amplified splitter for a two way split. Is the signal OK on the first TV with the cable box? It so try a cheap splitter upstream of the cable box. If the signal is too weak, the cable company can adjust gain in their equipment.Originally Posted by DJboutit
Look for 1GHz or more bandwidth on a passive splitter.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
On the tv with the cable box some channel flash blink other channels are just fine
Call the cable company. They should give you a strong signal.Originally Posted by DJboutitRecommends: Kiva.org - Loans that change lives.
Get a distribution amp like the one in your first post.Originally Posted by DJboutit
If the signal is crap coming into the house the distribution amp won't help. TV sets have lots of RF amplification already.
I recall these kinds of problems when people were tapping free connections in the apartment building cable closet.Recommends: Kiva.org - Loans that change lives.
Used to have a problem like that.
The cable compnay put a device like that on the house and that solved all of the problems.
But it turned out that the cable to the house had to be replaced in the first place.
If you have underground wires that may be something to look into -
The big test for the cable company is to show that the incoming line to the first cable box/TV works. Beyond that they will charge for correcting internal house cabling issues.Originally Posted by DJboutitRecommends: Kiva.org - Loans that change lives.
Can I use 3.5db splitter for cable and internet?
By peggypwr1 in forum Newbie / General discussionsReplies: 13Last Post: 18th Apr 2012, 09:07 -
Coax cable splitter question
By txmt in forum Newbie / General discussionsReplies: 9Last Post: 17th Sep 2011, 23:06 -
Composite cable splitter
By danielmak in forum Capturing and VCRReplies: 4Last Post: 8th May 2011, 05:12 -
Should I invest in a 2ghz coax splitter for a cable modem?
By yoda313 in forum ComputerReplies: 4Last Post: 23rd May 2009, 09:06 -
HDMI cable splitter
By snadge in forum DVB / IPTVReplies: 6Last Post: 21st Feb 2009, 11:24
