I am a total newbie so bear with me. I made a video slideshow set to music of my daughters wedding with text. I can save it to my media player and my computer. The problem is no matter what I do I can not convert it to a DVD you can playback on the tV with a DVD player. I keep getting an error that it is not formated right. I have try to burn it with the windows media player and Nero 7 Ultra Edition. I just don't know what I am doing wrong. I have blank CD and DVD disc.
Can anyone please help me. This is very important to me since it is my daughter's wedding.
Thank you so much
What did you create the slideshow with?
What type of video format is it in now? -
I used the windows movie maker and and tried to use the option to copy to cd but that will not play in DVD player
I'm not familiar with movie maker.
Did it give you an option of output format?
VCD, SVCD, or DVD? -
In the windows movie maker it only gives it the option to copy to cd. It looks like it completes it successfully but then it won't play. I then sent the file to the Nero 7 Ultra Edition and chose the option to copy to SVCD and that looks like it copies successfully. But when I try to play it in the DVD player it says this disc does dot have the playback option and is not formatted correctly. I am using a DVD-R and I tried using a CD-R disc. Am I using the wrong type of disc? I am sorry I am so clueless with this.
Thanks for your patience. -
VCD and SVCD should go to a CD-R.
Can you "explore" the discs you have already burned in Windows Explorer and see what is on the disc? -
it does not read it. I can start over if you give me some pointers.
I don't like "all in one" programs like Nero but since you already have it I would just create the slideshow in Nero.Originally Posted by rsmith2041
I have an old version of Ulead Movie Factory installed on my computer....just to create a simple slideshow.
Just make sure your your output is set to DVD quality....at least.
There are better slideshow programs than Nero and Ulead....free ones too like SSMM (Slide Show Movie Maker)
but they may have a steeper learning curve than something like Nero.
Cut Out Segments Of Video Using Womble MPEG Video Wizard DVD
By luckyace in forum Newbie / General discussionsReplies: 2Last Post: 4th May 2017, 04:46 -
Womble MPEG Video Wizard DVD is re-encoding video, claiming not to (FIXED)
By Brad in forum Authoring (DVD)Replies: 11Last Post: 2nd Mar 2012, 21:28 -
What.When) is DVD video (or mpeg video for DVD) pixel ratio 1:1 or 1:1.09
By perfection in forum Newbie / General discussionsReplies: 3Last Post: 21st Mar 2008, 08:05 -
Womble MPEG Video Wizard - adding video files to dvd maker help?
By nightrider in forum Authoring (DVD)Replies: 3Last Post: 5th Mar 2008, 09:52 -
can faulty/bad dvd-video dvds make ripples/whitelines in video?
By wiak in forum MediaReplies: 3Last Post: 22nd Jul 2007, 13:08
