Hi Everyone
I'm trying to covert a MKV file in Xenon MKV and this error is appearing:-
Failed to open MPEG file video.mpg
Error importing video.mpg: BitStream Not Compliant
Could anyone please help me out with how to fix this one.
Cheers
Thanks for your quick reply!
Here is the file :-
General
Complete name : D:\\MadMax1hdtv\Mad Max 1 [1979] 720p x264\M.M.I_by_lorenzoo.mkv
Format : Matroska
File size : 5.25 GiB
Duration : 1h 33mn
Overall bit rate : 8 067 Kbps
Encoded date : UTC 2008-10-19 00:23:40
Writing application : mkvmerge v2.3.0 ('Freak U') built on Sep 8 2008 18:32:16
Writing library : libebml v0.7.7 + libmatroska v0.8.1
Video
Format : MPEG Video
Format version : Version 2
Format profile : Main@High-1440
Format settings, Matrix : Default
Codec ID : V_MPEG2
Codec ID/Info : MPEG 1 or 2 Video
Duration : 1h 33mn
Bit rate mode : Variable
Bit rate : 7 266 Kbps
Nominal bit rate : 40.0 Mbps
Width : 1 280 pixels
Height : 720 pixels
Display aspect ratio : 16/9
Frame rate : 23.976 fps
Colorimetry : 4:2:0
Scan type : Progressive
Bits/(Pixel*Frame) : 0.329
Stream size : 4.72 GiB (90%)
Title : Mad Max I
Language : English
Audio #1
Format : AC-3
Format/Info : Audio Coding 3
Codec ID : A_AC3
Duration : 1h 33mn
Bit rate mode : Constant
Bit rate : 192 Kbps
Channel(s) : 2 channels
Channel positions : L R
Sampling rate : 48.0 KHz
Stream size : 128 MiB (2%)
Title : Inglés
Language : English
Audio #2
Format : AC-3
Codec ID : A_AC3
Duration : 1h 33mn
Bit rate : 448 Kbps
Channel(s) : 6 channels
Channel positions : Front: L C R, Surround: L R, LFE
Stream size : 299 MiB (6%)
Title : Español(Castellano)
Language : Spanish
Text
Format : UTF-8
Codec ID : S_TEXT/UTF8
Codec ID/Info : UTF-8 Plain Text
Title : Español
Language : Spanish -
Yes I was going to watch it on the Xbox360. Do you think that is still possible with another app that will preserve the HD?
Cheers -
You could convert it to an HD XviD (AVI) or MP4 file, both which the 360 should play with no problems.
XviD4PSP will convert it to AVI, and Handbrake or EncodeHD will convert it to MP4.
To play AVI or MP4 on the Xbox 360, you need to be able to connect to Xbox Live to get the codecs.
If you can't connect to Xbox Live, then Encode360 will convert it to WMV, but will take forever to do it...
MKV guide, Play MKV, MKV to AVI, MKV to DVD, MKV to MP4, MKV to Blu-ray
By Baldrick in forum Newbie / General discussionsReplies: 55Last Post: 29th Jun 2012, 11:19 -
How to play MKV, MKV to AVI, MKV to DVD, MKV to Xbox 360 or Playstation 3
By Baldrick in forum Video ConversionReplies: 2Last Post: 8th Mar 2012, 02:45 -
mkv to avi with xvid4psp! It's killing me! Help pls!
By Ramazan in forum Video ConversionReplies: 1Last Post: 28th Sep 2011, 07:52 -
Mkv to DVD9...Pls Help !
By john_triton in forum Newbie / General discussionsReplies: 2Last Post: 11th Oct 2008, 06:57 -
mkv to avi , help pls
By a_n00b in forum Video ConversionReplies: 3Last Post: 4th Jan 2008, 04:17
