I made some single-angle and multi-angle video clips and each one is in a separate VTS which i then joined to make one movie.
I used Maestro to do this, the only reason that i made it with separate VTS's was because i couldn't figure out the encoding settings i needed to use to get Mixed Multi-Angle to work.
I want to join all the videos together so that they play in a single VTS and I found a simple guide for how to do this here -
http://members.dodo.net.au/~jimmalenko/test.htm
I followed this guide exactly but unfortunately i ended up with a DVD that only had one angle and the timing and chapters were all messed up.
(Just so you know, all the videos have the same properties, plus every Multi-Angle video has the same number of angles).
Is there something else i need to do in VobEdit or IfoEdit to get it to work with Multi-Angle or are there any other programs that will join these types of files successfully?
Thanks for any info you can give me.
Sorry if this is the wrong forum for this question but it seemed to be the closest match.
I guess dvd authoring would be a better forum for this so I'm moving you.
Mixed Multi Angle DVD Encoding Problem
By werdna1900 in forum Video ConversionReplies: 3Last Post: 11th Jun 2009, 04:32 -
Backup a multi angle DVD
By src2206 in forum DVD RippingReplies: 1Last Post: 9th May 2009, 00:34 -
Joining vobs without VTS and then getting VTS in the end?
By BurnBabyBurn in forum EditingReplies: 7Last Post: 23rd May 2008, 11:28 -
Multi-Angle DVD-9 to Single-Angle DVD-5 help
By rayden54 in forum DVD RippingReplies: 6Last Post: 11th Sep 2007, 20:44 -
Multi angle - dilemma
By flipzoso in forum Newbie / General discussionsReplies: 1Last Post: 29th May 2007, 02:36
