Hi everyone, is there a tool to do this task?
I already tried to use Nero to burn a data disc but it only allows 1 audio track.
Try ConvertXToDVD or freeware programs like FAVC or DVD Flick or something other than Nero and you may have better luck. I'm assuming you are re-encoding the file to MPEG-2, then authoring it to a DVD? That's a bit more than just burning. And I would recommend ImgBurn for burning and leave Nero out of the process entirely.
If you are making a authored DVD, then it wouldn't be a data disc.
Or are you making a Divx data disc for a set top player?
A bit more information would be helpful.
Could not perform end of disc-at-once on dual layer dvd only
By Subhash in forum DVD & Blu-ray WritersReplies: 20Last Post: 25th May 2009, 14:09 -
data on dual layer dvd disc......
By dvstorm in forum MediaReplies: 4Last Post: 23rd Feb 2009, 20:21 -
can I burn 2 AVI files to dual layer with toast
By BattyRoy in forum MacReplies: 6Last Post: 10th May 2008, 01:10 -
Convert from 2-audiotrack file to 1-audiotrack
By MarquisdeOz in forum AudioReplies: 2Last Post: 21st Dec 2007, 09:44 -
Disc copy of a dual layer disc
By kingjames in forum Newbie / General discussionsReplies: 3Last Post: 1st Oct 2007, 14:52
