I am working on a setup where I get analog source in PAL through RCA cables, encode it MPEG-4 (preferably via hardware encoder) and push it to my streamer via Unicast.
Right now, I have a computer that will have a capture card and process the signal.
I'd like to know what capture cards you suggest and what software/hardware solution I should try to convert the signal in real-time and push it out of this "broadcaster" computer I have now.
Thanks,
SM
Ok, this is my update:
I started using GraphEdit to bypass VLC's low-quality output (and lack of sound). What I have setup in my GraphEdit is the signal going through my HVR-1800 crossbar, demux'd, and mux'd back to a TS format and finally saved as .AVI.
However, my problem is that I'm doing a live stream so I don't know how to set the File Writer in GraphEdit to write to the file perpetually (starting from beginning when it reaches a certain size or smth).
Does anyone know how to write to an .avi file in a perpetual manner?
Thanks for your input!
SM
Encode with FFMPEG with multiple input files...
By RogerTango in forum Video ConversionReplies: 3Last Post: 20th Jun 2011, 01:12 -
AVT-8710 TBC & Lack of RCA Audio Input/Output - Will It Matter?
By NY2LA in forum RestorationReplies: 45Last Post: 25th Oct 2010, 19:53 -
Encode for RCA Lyra X2400 with Avidemux
By jazzy38 in forum Newbie / General discussionsReplies: 12Last Post: 9th Nov 2009, 09:22 -
DVD RCA audio to coax input
By Chicago in forum Newbie / General discussionsReplies: 4Last Post: 21st Nov 2007, 09:34 -
Portable DVD player that handles RCA input
By mbcdc in forum Portable VideoReplies: 7Last Post: 18th Sep 2007, 05:51
